Wheel stud removal
Wheel stud removal
Postby bike grim » Wed Aug 03, 2016 6:48 pm
Possibly been discussed before but a quick search revealed nothing. I was trying to update my MB outboard Disc wheel studs to fit SIP rims and the obvious happened.. I broke a wheel stud. None of them will budge and it's probably a no hoper but an engineer told me he could bore them all out and re tap if I supplied the appropriate reverse thread tap. Anyone ever done this before? It's a shame to bin an otherwise great front brake set up just because of the wheel studs.
Re: Wheel stud removal
Postby HxPaul » Wed Aug 03, 2016 8:01 pm
I'm not very sure about the hub studs on your scooter,but if there the same as standard hub studs,the heads on the studs are difficult to get a spanner on them.I've got some standard ones out by gripping them in a vice.I first soaked them in WD40 for a couple of days.
Postby Warkton Tornado No.1 » Wed Aug 03, 2016 8:07 pm
Sod your luck.
You can only try & accurately drill out the remnants so the original LH thread remains in the alloy hub.
It is possible but takes patience & accuracy.
Drill a dead centre pilot hole & gradually increase the drill size until a thin walled tube remains & then you can usually collapse that inwards to be tempted out. Loads of penetrating oil helps, as will heat. WD40 is not a true penetrating oil. It is moisture dispersant.
Despite what you’ve been told, you cannot ‘re-tap’ back to the original size without welding the hole or heli-coiling.
Postby bike grim » Wed Aug 03, 2016 8:08 pm
Yes they are the same as standard, the MB disc just used a modded standard hub.
They aren't budging at all with heat, wd40, vice, locking 2 nuts to push it out whilst using a ground down 12mm socket on the head to help it along ( how I snapped it) thought about getting someone to weld a length of bar to it to add some leverage. But I need all 4 of them out really so the drilling then re tapping or even helicoil seemed a good idea if I could get hold of the left hand thread tap or helicoil kit?
Postby bazza3004 » Wed Aug 03, 2016 8:59 pm
Did a rear hub couple of years ago. 3 came out no problem but typically one was not for budging no mater how i tried. I finally thought sod it and cut the stud off level with the hub lug then drilled it out with a slightly larger drill each time and as said previously once thin enough i was able to tap the remaining thread inwards with a dot punch. Good luck.
bazza3004
Postby bike grim » Thu Aug 04, 2016 7:38 am
Thanks for the advice, I'll try and get on a mates pillar drill and have a go. Fingers crossed.
Postby holty » Thu Aug 04, 2016 8:11 am
another good way is to drill out so far, then weld a bolt onto the side where the socket fits, should come out easy, providing you have a welder of course.
holty
Postby terryj » Thu Aug 04, 2016 9:09 am
i had a broken stud in an head set removed once using a spark eroder and never damaged headset or threads so if you know a friendly tool maker
terryj
Postby Warkton Tornado No.1 » Thu Aug 04, 2016 11:37 am
Post by bike grim » Wed Aug 03, 2016 8:08 pm
Helicoil thread inserts are very common in certain industries such as Aerospace & Motorsport where alloy castings will have them fitted from the outset.
‘Our’ more common metric threads tend to be all RH such as M8 x 0.5, M6 x 1.0, M7 x 1.0, M8 x 1.25 & the M14 x 1.25 spark plug threads. Even I have Helicoiling equipment for those sizes.
The more universal kit sizes are often much more obtainable (& cheaper!) than the more unusual M10 x 1.0 LH hub hole size.
If all else fails, Beedspeed appear to do an oversize hub stud that utilises a Whitworth thread.
https://www.beedspeed.com/lambretta-stud-oversize-p-8195.html?osCsid=1556si5anv42c3orrjom4ouhg1
Postby bazza3004 » Thu Aug 04, 2016 1:23 pm
holty wrote:another good way is to drill out so far, then weld a bolt onto the side where the socket fits, should come out easy, providing you have a welder of course.
Thats good advice.
bazza3004
Postby Knowledge » Thu Aug 04, 2016 2:04 pm
The only time I tried this technique, the stud was so hard, it didn't take the weld: the metal of the stud just seemed incompatible with the weld rod (wrong melting point).
Having said that, I would try it again in your circumstances.
Postby bike grim » Fri Aug 05, 2016 7:40 am
Great news, a fellow club member has come to the rescue and removed all of the old studs by welding a flat bar to the bolt heads and turning them out ! Result. Thanks for all the help and suggestions
Postby Digger » Fri Aug 05, 2016 8:28 am
Result... Well done that man
Digger
Postby corrado » Fri Aug 05, 2016 9:13 am
Great stuff, I no longer feel responsible. :D
corrado
Postby Wack » Fri Aug 05, 2016 9:25 am
Right or wrong I always copper grease hub studs in to prevent them seizing.
Postby bike grim » Fri Aug 05, 2016 10:13 am
corrado wrote:Great stuff, I no longer feel responsible. :D
Hahaha
