Post by Leotech » Mon Aug 01, 2016 10:37 pm
My day job is servicing shocks and forks for off road competition motorcycles. Recently a friend gave me an old Taffspeed unit that had developed a leak.
I got it in pieces as it is rebuildable but it used a strange type of seal, Taffspeed said they didn't sell service kits for them and I have been struggling to locate a seal through my network of contacts. I am currently looking into he feasibility of making a new seal head and using a more common seal.
With the BGM unit being more current it may use a more readily available seal. They may even offer a service kit, is it gas pressurised?
Warkton Tornado No.1 wrote:Post by Leotech » Mon Aug 01, 2016 10:37 pm
I’m watching this Post with interest as I too have a BGM rear shock absorber that I suspect may need checking out as I think the seal(s) may be leaking.
I believe that they only use oil (not gas pressurised).
I also have a GAZ rear shock absorber that I suspect is in a similar state.
Finding any information about either is proving fruitless. Both units must be serviceable, but I guess that neither manufacturer wants to make it easy for anybody proficient enough to do so....
Post by Leotech » Tue Aug 02, 2016 9:15 am
If you remove the spring it will become apparent if the oil has leaked.
Im in a similar position with the Taffspeed unit. The seals won't have been manufactured exclusively for them but its finding who made them. Taffspeed just said the manufacturer had gone but Im guessing the manufacturere will have bought the seals in for the shocks and not made them in house. Its a shame a good product is deemed useless for the want of a ten pound piece of rubber.
Post by HxPaul » Tue Aug 02, 2016 10:28 am
Lots of different shapes and sizes of oil seals.
https://www.google.co.uk/search?q=sizes ... E_rn5eM%3A
byron wrote:thanks. interesting replies.
happy to let my BGM shock be dismantled to see how serviceable they are; if you fancied another one in bits on your bench Leotech..?
[they do damp with just oil, not gas]
Re: BGM rear shock ~ rebuildable ?
Post by Leotech » Wed Aug 17, 2016 4:29 pm
The Taffspeed shock I had that was leaking, I've managed to source some seals to repair it.
It just needs tested now to see if it will not leak! The only seal I could get wasn't exactly as the original so thats why it needs road tested.
Leotech wrote:The Taffspeed shock I had that was leaking, I've managed to source some seals to repair it.
Unread postby HxPaul » Fri Aug 19, 2016 7:17 pm
I once had a hydrailic inboard front disc and the seals had become hard and started to leak.I searched everywhere for new seals to no avail,a friend of mine suggested trying rubber o rings,with nothing to loose (except possibly my life) I sourced some o rings and they worked perfectly never leaking and the brake was good.
Warkton Tornado No.1 wrote:....but the special section seals will work better because they are designed to distort so that the piston retracts a little once the pressure is off.
Dave Webster may have been a pedantic character, but he knew what he was on about by advocating the use of the correct seals in his brake conversions..
