could someone tell me the length of this (missing) item for a mate's engine rebuild, ta
petemaisey wrote:If you upgrade to the taller spring you will also need the deeper crankcase cover.
Pete
peejay wrote:thanks guys for the replies.
my mate would like to keep it as original if possible so was curious as to the different length needed as we only have series 3 to hand
davej wrote:I am the person looking at this Series 1 engine at present, The situation I have is that the original Spring has a length of 29mm and when re fitting the Top Cap starts to engage on the splines and tightens up very quickly which means the Spring can be rotated very easy. Am I correct in thinking that I should have more compression on the Spring similar to a Series 3 engine, Any guidance would be appreciated. Thanks
