running in
running in
Postby panda » Thu Jul 28, 2016 5:11 pm
hello folks.... I have just rebuilt my 150 engine after the main seal went after the iom rally and was wondering how many miles will I have to do to run it in again,I have replaced all the bearing and oil seals and a brand new chain and clutch but the top end just the same. ;)
cheers
panda
Re: running in
Postby hullygully » Thu Jul 28, 2016 5:32 pm
no running in period 8-)
Re: running in
Postby Warkton Tornado No.1 » Thu Jul 28, 2016 5:46 pm
There may be contradiction to this opinion (like ride it as if you stole it :!:) but the rules to which I’ve adhered on a road scooter are:
• Use the gears up & down so that you are varying the revs all the time. In other words, play tunes on your gearbox! For example, from fourth to third where the revs (& cooling) will increase but not the load
• Gradually increase the revs as mileage increases
• Don’t labour the engine (particularly as the cooling is relative to fan speed)
• Don’t be tempted to add more oil
• Don’t be tempted to roll off the throttle downhill or approaching a stop/junction etc
• Keep your left hand hovering over the clutch
• Let the engine run @ a higher tick-over after any run so that it can cool down, rather than switch off if it is hot
I hope this helps, but it is only my opinion & offered as a genuine response. ;)
Re: running in
Postby ToBoldlyGo » Thu Jul 28, 2016 6:06 pm
I always understood that if you changed the rings it was good practice to give them a few miles to bed in properly. I don't know if you have or not, but it's probably still a good idea if you've had it apart.
Re: running in
Postby HxPaul » Thu Jul 28, 2016 6:22 pm
panda wrote:hello folks.... I have just rebuilt my 150 engine after the main seal went after the iom rally and was wondering how many miles will I have to do to run it in again,I have replaced all the bearing and oil seals and a brand new chain and clutch but the top end just the same. ;)
cheers
If thats all you've changed,I wouldn't bother about having to run it in.Just take it easy for the first 100 miles to bed in the new bearings,clutch and chain.
Re: running in
Postby panda » Fri Jul 29, 2016 12:10 pm
many thanks :D
panda
Re: running in
Postby Warkton Tornado No.1 » Fri Jul 29, 2016 12:15 pm
Oops! :roll:
I took it for granted you'd refreshed the top end & needed to bed in rings to a fresh bore.
My mistake, but what I said may be useful reference for future/others..... :)
Re: running in
Oops! :roll:
Re: running in
Postby kennystag » Fri Jul 29, 2016 12:42 pm
Hi Mark,
I was wondering why you said what you said, as the top end was not touched lol.
Stag
kennystag
