Setting gears '
I've just spent the day trying to set and adjust the cables and I've failed 'when I managed to get first it was six or seven mill past the arrow ,then ide take it back to nuteral & it would then jump into second when I spun the back wheel , at one stage I had it going upto fourth & then nothing would not change back down , there's a bit of ware on the gear linkage play on the main gear pivot pin , the clutch Spring seams weak as well so I'm going to order a new gear linkage & clutch Spring tomorrow . When I stripped the engine a replaced the sliding dog, the Spring & the pawles drive bearing , we'll all bearings , could it be a mixture of worn parts & maybe the new pawles being stiff & needing wearing in ??
I did check the end plate float and ended up with a 1.5 spacer .
Any suggestions
Any suggestions
