by scarkey » Tue Jul 12, 2016 6:25 pm
Can someone please point me the right direction to finding the correct pressure for SIP Performers, I have read lots of options and opinions about other tubeless tyres but I am really seeking something abit more technical in regard to Performers.
scarkey
by ToBoldlyGo » Tue Jul 12, 2016 6:31 pm
There are no correct pressures. They're tyres, the same as Michelin's or Conti's. Inflate them to suit yourself.
by roli150lam » Tue Jul 12, 2016 6:48 pm
yes exactly as long as you don,t exceed the manufacturers parameters.
roli150lam
by burnside » Wed Jul 13, 2016 9:16 am
Worth asking SIP who make them? Especially if putting them on SIP tubeless rims. They should tell you what the minimum and maximum pressures will be, personally I wouldn't just go with the pressures quoted in a 50 year old Lambretta manual for modern tyres on modern rims.
burnside
by scarkey » Wed Jul 13, 2016 11:25 am
Thats what I would like to know, what is the min and max pressure for these on SIP Rims. I cannot see it for looking on the SIP Site.
MB suggests as To boldly Go says just keep adding a couple of PSI to suit your riding etc but thats not a specific number.
scarkey
by burnside » Wed Jul 13, 2016 1:47 pm
SIP rims have a tendency to loose pressure if under a certain psi, I read somewhere that this was around the 30 mark, which is high for your front wheel. Certainly explains why my front needed topping up on a regular basis. I now run the front at 25psi and this does seem to hold better.
burnside
Users browsing this forum: B1gD0gu3, Baidu [Spider] and 20 guests
