xenia1 wrote:Having had lots of packets of n.o.s Innocenti fixings i can confirm they were a brightish/satin plating. Some were brighter than others but zinc plate goes dull with age anyway.
I take it youve bought the d.i.y kit with anodes, battery pack and salts? I had one of these from Frosts and tbh didnt really have a lot of luck with it and in the end had what i didnt have n.o.s replated professionally.
Ps- if you do have good results and any plating comes out too bright its easy to tone it down by using a dilute solution of phosphoric acid diluted with hot water in a spray bottle. Leave it wet for a minute or two and wash off with hot water..
Andy.
Jazzy b wrote:Your a very knowledgeable guy Andy
Warkton Tornado No.1 wrote:Do you have a finished budget on the total equipment costs, please?
It would be good to see some photos if you could do the parts justice.
eyeguy wrote:I agree with Xenia, the kit I purchased was from caswell plating here in the states. I think the cost of the system was $150.00. This included most things. The rectifier is separate. I bought of the bay for $100.00. However the cleaning part is very important as stated. I bought a small blasting cabinet. I am using a fine grit glass bead which is suppose to be the best way to prepare surface. Of course you need to degrees all parts. The caswell system has a manual which is very good to follow. Look at their site. Not sure if you could buy from them being out of country. I guess you could but the cost would be more. I am out of town until Friday but will post some pics when I get back. Again I think the parts look good but longevity is yet to be determined.
Hope this helps
Eyeguy
Users browsing this forum: No registered users and 112 guests
