clutch slip ?
clutch slip ?
Postby steve chapman » Sat Jul 09, 2016 11:24 pm
Just rebuilt my engine and when i start to move of its fine then slips for a second then bites again , as if i am pulling the clutch in and out quickly, it is fine if i only go very slow , any ideas ? , steve , ps hope this makes sense
steve chapman
Re: clutch slip ?
Postby Raveydavey » Sun Jul 10, 2016 7:09 am
Assuming, new plates and correct installation, Either it's the Cable too tight. It shouldn't be tight at all. Wind the adjuster out until the clutch arm is fully back, and try again.
Or it's the spring height / plate thickness combo. Fully compress the clutch with clutch compressor, plates should just separate,(1.5mm gap) not rattle around.
Good article on here http://www.ilambretta.co.uk/clutch.html
?..or the springs are pants.
Raveydavey
Re: clutch slip ?
Postby coaster » Sun Jul 10, 2016 7:53 am
Not had the problem myself but the front cush drive can give similar symptoms if it the splines aren't engaged under the top hat.
Re: clutch slip ?
Postby HxPaul » Sun Jul 10, 2016 8:53 am
coaster wrote:Not had the problem myself but the front cush drive can give similar symptoms if it the splines aren't engaged under the top hat.
+1
Re: clutch slip ?
Postby Adam_Winstone » Sun Jul 10, 2016 11:15 am
+ lots of times!
Re: clutch slip ?
Postby steve chapman » Sun Jul 10, 2016 5:16 pm
Thanks for the replys , been out on it again today, seems to be in second gear when it does it , good point about cush drive , because it only slip for a second and then re bites , not sure if its clutch or gears slipping , steve
steve chapman
Re: clutch slip ?
Postby steve chapman » Sun Jul 10, 2016 6:00 pm
Thanks guys will have a look
steve chapman
Re: clutch slip ?
Postby Adam_Winstone » Sun Jul 10, 2016 7:27 pm
You can look for wear on the front sprocket, which might help to identify the issue. As for curing it, you can change the sprocket (some machined too low) and fit a new sprocket assembly spring, however a good check to see if this is the case is to leave everything as it is but to fit a suitable washer under the sprocket assembly to jack it up and to add more preload to the spring. This may or may not put your sprockets out of alignment, which in turn can lead to chain wear, however, it allows you to test it to see if this is the reason for the feeling of clutch slip.
CamLam sell, or did a while back, shims of various thicknesses as they had found incorrectly machined sprockets to be an all too common problem, however, they were good enough to tip me off to the shim that fits between rear sprocket and endplate bearing being the correct size to do the same job. The shim needs to be fitted between the oil thrower washer and the splined column of the front sprocket assembly.
Re: clutch slip ?
Postby steve chapman » Sun Jul 10, 2016 7:36 pm
Thanks Adam , its a new front sprocket, but didnt change the other components , could it be that spring isnt as good as it could be , when i built it i was pretty sure that the top hat had seated properly , but looks like this is where the problem is , Steve
steve chapman
Re: clutch slip ?
Postby Adam_Winstone » Sun Jul 10, 2016 8:54 pm
Yes, springs can go soft. A pal of mine suffered from accidentally fitting a SI spring, which are different; shorter and not as strong.
New sprocket could even be the issue as many are incorrectly machined, allowing the assembly to ride-over / spin.
Re: clutch slip ?
Postby steve chapman » Mon Jul 11, 2016 9:26 pm
Ordered a full cush drive set , so fingers crossed , once again thanks everyone , Steve
steve chapman
Re: clutch slip ?
Postby steve chapman » Thu Jul 14, 2016 7:17 pm
So ive bought a full cushdrive set , and a af cassette clutch and its still doing the same bloody thing , £300 down the drain , ive noticed its only doing it in 2nd gear , which i must admit i hadnt noticed, i am now thinking gearbox ? , any help would be great , steve
steve chapman
Re: clutch slip ?
Postby Warkton Tornado No.1 » Thu Jul 14, 2016 8:34 pm
Presumably there’s nothing non-standard about the gearbox?
It occurred to me that if it is a special close ratio gearbox with the cluster comprising pressed on gears as some are, then the interference fit may have failed. The same would occur with the keyed type if the feather key sheared...
Might be clutching @ straws, but it shows I’ve given your problem some serious thought :?
Re: clutch slip ?
Postby steve chapman » Thu Jul 14, 2016 9:38 pm
Italian gp200 box new sliding dog , didnt change gear selector spring or ball bearings , thanks for your reply though
steve chapman
Re: clutch slip ?
Postby dickie » Thu Jul 14, 2016 9:41 pm
Second loose gear wrong way round and not catching sliding dog properly?
Re: clutch slip ?
Postby steve chapman » Thu Jul 14, 2016 10:00 pm
If the second gear was in wrong would it give that feeling ?
steve chapman
Re: clutch slip ?
Postby Warkton Tornado No.1 » Thu Jul 14, 2016 10:05 pm
Post by steve chapman » Thu Jul 14, 2016 10:00 pm
Ha! Never tried it! But it wouldn’t hold second gear as the dogs would be misaligned... :x
Re: clutch slip ?
Postby Adam_Winstone » Thu Jul 14, 2016 10:20 pm
Sorry to hear that you're still struggling with this one but at least you've ruled a few things out, which is what problem solving is all about.
I only suggested that you tried a 50p shim to preload the front sprocket assembly and test to see if that was the cause, not spend £300 on parts :shock:
Good luck getting it sorted.
Re: clutch slip ?
Postby steve chapman » Thu Jul 14, 2016 10:33 pm
Not blaming anyone Adam , just trying to solve it , its doing my head in :x :x ,steve
steve chapman
Re: clutch slip ?
Postby Adam_Winstone » Thu Jul 14, 2016 10:44 pm
^... cool, I'll keep scratching my head. Interestingly, the most recent time that I suffered from this was after fitting one of the BGM front sprockets that turned out to be soft (issue rectified and new sprocket, gasket and gearbox oil sent out by Scooter Center, without questioning it... good service) and I too bought an AF clutch and new front sprocket spring in an attempt to rectify the problem. I ended up still having to fit a shim under the front sprocket assembly to stop the sensation of clutch slip, which is still in there to this day :!:
I guess that you should be checking out that gearbox and sliding dog arrangement and continuing to rule one thing out at a time.
Best of luck with it.
