by corrado » Sun Jul 03, 2016 3:15 pm
I've got a blank casing so think I'm correct in thinking that I can fit either the S3 or GP brake depending on which cam and pegs I fit. Am I correct and what's the pros and cons for either set up?
corrado
by gaz_powell » Sun Jul 03, 2016 4:57 pm
Yes you can use either, just match cam to shoes. Pegs are all the same
I use GP set up in all my bikes just for ease so I only have to keep one set of shoes on shelf, but equally I've set LI up for people and they have worked no issue.
by Adam_Winstone » Sun Jul 03, 2016 9:45 pm
Either type of pegs can be used but GP ones must use W clip and LI/SX/TV must use circlips as the profile of the locating recess is different.
by corrado » Sun Jul 03, 2016 10:47 pm
I've got both sets of pegs Adam. I think I'm leaning towards the GP as parts are easier to get and the W clip is less fiddly than circlips. I was trying to get my head around whether or not the thicker cam of the S3 gave a more even spread of contact area on the pads to the drum, but assume that the add on clip on the GP shoes evens it out.
corrado
