Clocking
Clocking
Postby Scooterlam » Fri Jul 01, 2016 11:58 pm
Somewhere along the way my itilian GP picked up an indian speedo.
I"m not bothered by the Foriegn object (little pun intended).
What bothers me is the unobtainable 120mph staring at me,.
I want to change it to an equally unaobtainable 90mph white faced item but cant bring Myself to loose
my hard earned milage.
Are the remade ones robust enough to take apart spin the wheels and putback together.
Btw its far to many miles to use a drill.
Any tips appreciated.
Scooterlam
Re: Clocking
Postby landybretta » Sun Jul 03, 2016 6:36 pm
I believe that you can just buy a replacement face. Scooter Restorations do one but out of stock at the moment.
Must be others if you search the net.
landybretta
Re: Clocking
Postby MK Monty » Sun Jul 03, 2016 7:52 pm
I tried to do this on my LI. The workings tend to be brass worm drive meshing with a brass drive to the rotating wheels. The remade ones are nylon. They are a million miles apart quality wise. I don't want to be accused of telling you how it's done but a few screws and it's a simple matter of turning the tumblers. I would stop early and use the drill to go onto the numbers you want so everything lines up. Or you can end up with a digit half and half. I did mine to retain the original mileage/kilometres. The gauge was bust so no pain no gain. Unfortunately as it went onto 1 more thousand miles it stuck. The speedo worked but the teeth on the drive had worn out. Basically not worth the fuss. I now have a digital speedo and I lost the instructions on how to set the wheel diameter for the correct speed. I would need to change this then do a drill with a magnate to wind it on to the correct setting. The bloody MOT man keeps recording the trip mileage anyway. Not worth the fuss.
MK Monty
Re: Clocking
Postby Scooterlam » Sun Jul 03, 2016 10:01 pm
Thanks for the replies.
Unfortunately I don't think the face swap will work as they're different speeds.
Guess I'll just have to keep tuning till I get to 120mph.
Scooterlam
Re: Clocking
Postby xenia1 » Tue Jul 05, 2016 10:28 am
Scooterlam wrote:Thanks for the replies.
ZX10R engine will do it, probably go onto around 160.... :mrgreen:
xenia1
Re: Clocking
Postby Digger » Tue Jul 05, 2016 10:58 am
The needle still moves in the same way. :?
Digger
Re: Clocking
Postby ToBoldlyGo » Tue Jul 05, 2016 12:29 pm
If you remove the mechanism it's quite easy to alter the tumblers (?) even if it is a bloody fiddle. I've done one myself. Although I've not used it since and I'm a bit dubious as to whether it will work or not.
Re: Clocking
Postby Toot » Tue Jul 05, 2016 6:06 pm
Jem Booth is your man to answer this question, he's repaired two original speedo's for me and set the clock to 0,000 on both.
Only used the SX one so far & it's been spot on.
Toot
Re: Clocking
Postby Jazzy b » Tue Jul 05, 2016 6:10 pm
What about a speedo face sticker ?
Jazzy b
Re: Clocking
Postby xenia1 » Tue Jul 05, 2016 7:55 pm
Toot wrote:Jem Booth is your man to answer this question, he's repaired two original speedo's for me and set the clock to 0,000 on both.
This
Jem also did my Tv1 speedo and can calibrate original ones to within 1mph..
xenia1
Re: Clocking
Postby Scooterlam » Thu Jul 07, 2016 11:50 pm
Unless I'm missing something, which is quite possible.
At 60mph my needle is roughly in the middle.
If I just changed the face it would read 45.
Scooterlam
Users browsing this forum: No registered users and 103 guests
