by La chevre » Tue Jul 08, 2014 7:54 pm
Hi all
Have a problem with my in board hydraulic brake. I purchased this in mid 80,s from Dave Webster.The internal piston doesn't seem to reset on activation of the brake lever.Ive split the hub a number of times, clamped down the internal piston re mounted onto hub yet still It seems to rub on the disc. Are spare pistons available or replacement matching parts (the dust ,cover on mine is now split) as I prefer the inboard hydraulic look and would like to retain on my s3.
Thx La CHevre
La chevre
by Fred » Wed Jul 09, 2014 9:50 am
Hello,you need to push the piston out using a punch via the banjo bolt. Clean the cylinder and piston. Then refit.
I'm using 2 of these dj hydraulics ,and neither have the dust seal anymore.
I believe the dust seals are from an old Renault 10. So if you live in France you may be able to obtain some.
I have an old seal,which is in bad shape which I may well try to get copied at a seal makers not to far from me.
Fred
Fred
by La chevre » Wed Jul 09, 2014 11:42 am
Ok Great.Discussed with dealers and none of them were particularly interested so appreciate the comment.BTW did you have a similar experience hence the treatment you suggested.
Thx Paul .
La chevre
by HxPaul » Wed Jul 09, 2014 2:52 pm
I had a hydraulic inboard disc brake and it leaked out of the seal.I tried everywhere to get a replacement seal,but could't get one.In the end I got an "O" ring the same size and fitted that.It worked perfectly and I used it every day for 3 years.
by lofty » Fri Jul 11, 2014 3:52 pm
a lot of conversions of that era (eg taffspeed, PM tuning)used a piston and seals from a MG Metro 4 pot caliper.. which are available from places like minispares and ebay..
lofty
by Fred » Fri Jul 11, 2014 9:46 pm
Yes,mine have stuck. Just take em apart when they do.
Fred
by wiener » Sat Jul 12, 2014 12:58 pm
hi don't know if this helps my original inboard disc seemed to binde when pads half worn split hub to find groove worn in bottom of back plate pad casing causing pad to get stuck tried to find replacement back plate but silly money done some surfing to find beedspeeds hydraulic back plate replacement comes complete with built in slave cyclinder piston and I cap perfect fit with original disc window half
cheers wiener
wiener
