Series 2 to Series 1
Postby Gino » Tue Jul 08, 2014 7:26 pm
Hi,
Not sure where to post this, so feel free to move to somewhere suitable.
Just wanted to see if anyone would be interested in this idea, its probably nothing new.
I have recently converted a Series 2 to look like a Series 1
In additional to the obvious parts : Head set upper and lower, headset clamp, headlight rim and horncast, to reduce vibration and to secure the horncast to the frame, ive developed a bracket to secure the horncast and electrical ternimal block to the frame without affecting the legshield.
As i said its probably not a new idea, but ive not found anyone selling the Series 1 Bracket.
Is it worth making a few? and selling?
The good thing is that you keep your existing Series 2, but change the look to a Series 1 and you can always return back if you change your mind ;=)
OK the parts to convert will probably set you back around £500 for original italian parts, but thats not too bad as you keep your scooter which you may have spent a lot on already. just an idea.
Gino
Re: Series 2 to Series 1
Postby steve c » Tue Jul 22, 2014 2:39 pm
turn the chrome ring around 180 degrees and redrill it,it chops the cables else,
unless you have a series 1 locking ring same goes series 1 to 2 , its the same part excepting the hole to locate it, I used series 2 shields and made a 6mm plate to the tb,
Currently stalled due to house moves and my painter having massive illness problems, so I will probably spray my self if the weather holds up
steve
steve c
