GP Clutch Arm Asssembly
Postby rossclark » Sun Jun 05, 2016 10:50 am
What's the correct sequeuence for the GP clutch arm assembly in the side case?
I can't remember, it's not covered in Sticky's book and I can't find a decent picture that gives a clue.
It has a groove for a circlip at the bottom, but none of the parts diagrams show one. It looks like, from the top it should be -
Circlip
Arm
Circlip
Shim
O ring
Casing
Shim
E clip
Pawl
Can someone confirm?
Re: GP Clutch Arm Asssembly
Postby Dimitrios_231 » Sun Jun 05, 2016 11:21 am
If pawl is the lever,I confirm ;)
Dimitrios_231
Postby rossclark » Sun Jun 05, 2016 12:09 pm
Cheers Dimitros, I was more wondering, though, if there should be a circlip below the pawl or whether it is just retained by the shaft?
Postby Dimitrios_231 » Sun Jun 05, 2016 12:22 pm
You can fit a circlip,but it is not necessary.
If you fit a a circlip ,the eyes of it can interact with the thrust bush.
Without a circlip,the thrust bush (fitted inside it's house) alone will 'lock' the lever in the correct position.
Dimitrios_231
Postby rossclark » Sun Jun 05, 2016 12:27 pm
Perfect thanks
Postby Scooterslag » Sun Jun 05, 2016 12:52 pm
whats the line up with a LI clutch arm assembly? just building up a chaincase now and don't know if the claw sits at the bottom holding the internal clutch lever on or is the claw on first as it enters the chain case, then the internal clutch lever then the circlip to hold it on? cheers Paul (sorry for the thread hijack)
Postby Dimitrios_231 » Sun Jun 05, 2016 1:04 pm
The parts book shows everything that you need for Li/SX/TV.
Dimitrios_231
Postby Scooterslag » Sun Jun 05, 2016 1:51 pm
Cheers for that ;)
Postby Dimitrios_231 » Sat Jul 23, 2016 4:08 pm
Found a pic in an old manual,it has a circlip at the bottom of the GP assembly,
don'y worry if you haven't fitted one,the pawl won't escape.
Dimitrios_231
Postby rossclark » Mon Jul 25, 2016 12:15 am
Thanks again.
Interesting that this diagram doesn't show the 'E' clip at all.
Postby Dimitrios_231 » Mon Jul 25, 2016 9:18 am
Yes,I also noticed,it seems that nobody is perfect ;)
Dimitrios_231
