Cracks on engine case around oil seal retaining plate
Postby Strummer10 » Sun May 29, 2016 2:35 pm
Hi All, sorry we have 2 cracks on an engine case where the bolts go into it to hold the oil seal retaining plate, just wondered if chemical metal / araldite is all that might be needed
Strummer10
Re: Cracks on engine case around oil seal retaining plate
Postby Digger » Sun May 29, 2016 8:42 pm
I'd get it welded.
Retaining plate = mechanical load.
Digger
Postby Warkton Tornado No.1 » Sun May 29, 2016 9:18 pm
I’m not contradicting excellent advice received in case my underbench spares get burgled(!), but it would be good to see a photo to judge. ;)
Postby rossclark » Sun May 29, 2016 10:25 pm
Does it retain the seal or the bearing?
I saw this posted on the other site and there was advice that said it is not 'load bearing' - I'm not sure I agree with that, I'd be inclined to repair it.
Postby Warkton Tornado No.1 » Sun May 29, 2016 11:35 pm
The seal plate locates the seal & bearing axially. In turn, the crank & sprocket drive is positioned via the drive side bearing with the flywheel side floating.
There is not a huge thrust load on the deep groove ball bearing IMO & I doubt that an alternative method or well engineered modification would cause a problem dependent upon the extent of the cracks which we’ve yet to see.
No point in elaborating on methods until then….
Postby Strummer10 » Mon May 30, 2016 7:08 am
Apologies, my post was not really clear above !!
The issue is at the back wheel end. The problem is there are 4 bolts that hold down a 'square shaped' washer in between the brake shoes that retains the rear wheel oil seal, but also retains the rear wheel bearing in place. Its 2 of the threads which take bolts (in the case of this indian GP) that have cracked, but 2 of the other threads are fine.
Strummer10
Postby Warkton Tornado No.1 » Mon May 30, 2016 12:06 pm
Even more reason for:
Postby Strummer10 » Mon May 30, 2016 5:03 pm
Apologies the posting a photo on this site is not straightforward, but I will check it out and get one up in next day or do. Cheers
Strummer10
Postby Warkton Tornado No.1 » Mon May 30, 2016 8:20 pm
If you haven’t already got it, ‘Dropbox’ is an easy ‘host’ to use for transfer of images. Even I know how to use it! :lol:
Postby Digger » Tue May 31, 2016 8:10 am
Strummer10 wrote:Apologies the posting a photo on this site is not straightforward, but I will check it out and get one up in next day or do. Cheers
It's the same as any other forum - stick your pictures on a hosting site, Photobucket, Flickr and use the links in your post.
Digger
