cutting out
cutting out
Postby JBG584 » Thu May 19, 2016 10:22 pm
Hi
scoot series2 owned by me since 1960 starts great runs well but just cuts out after about 10 miles and wont restart for about 15 minutes running on all original electrics never changed.Had new plug
JBG584
Re: cutting out
Postby MickYork » Fri May 20, 2016 7:27 am
Is there a spark when it cuts out ?
2 options, either fuel or electrics.
For the fuel, check the flow rate from the tank, clean filters (air and fuel), strip and clean carb and check float bowl is not sticking.
For the electrics....not much to really check it's more a question of replacing parts and seeing if the fault disappears. Options for potential faults are, the condenser, coil, HT Lead, points and the stator itself.......plus the option of the cut-out wire shorting (but this would be more intermittent).
Good luck :)
Re: cutting out
Postby kennystag » Fri May 20, 2016 10:40 am
Try another plug. It would amaze you how many new plugs that are fooked. Check to see if you have petrol in the bowl. The other thing I would like to mention is, it could be a wire is breaking down when hot, and back to normal when cold. After you have done all the other checks. Take the flywheel off and check the stator wires and parts. Just some thoughts .
Good luck
Stag
kennystag
Re: cutting out
Postby Warkton Tornado No.1 » Fri May 20, 2016 1:16 pm
What they said but check fuel cap admits air as your symptoms are similar to the vacuum that results with no breather to the tank.
Re: cutting out
Postby Scooter Paul » Fri May 20, 2016 4:34 pm
Fuel cap blocked is a good call but I also favour the previous comment about the condenser failing when hot. They start working again when cool.
Paul.
Scooter Paul
Re: cutting out
Postby JBG584 » Fri May 20, 2016 8:13 pm
thanks will check all points that you mentioned.Could be the condenser been on scoot since I got her in 1960
JBG584
Re: cutting out
Postby lammydave » Sat May 21, 2016 6:39 am
coil, once warm, cuts out
or blocked breather
lammydave
Re: cutting out
Postby kennystag » Sat May 21, 2016 1:08 pm
Any luck JBG584.
Stag
kennystag
Re: cutting out
Postby JBG584 » Sat May 21, 2016 6:52 pm
will have to work on it next week cant get to work on it at the moment.
JBG584
Re: cutting out
Postby Rich Oswald » Sun May 22, 2016 10:58 pm
My money's on condensor.
