New front dampers not the same!
Postby 507VBH » Wed May 18, 2016 10:07 pm
Hi,
Just bought a Scootopia front damper kit for my Li series 2. While playing around with them I noticed that the bump resistance of one unit is much less than the other. However the rebound force is pretty similar. I'm a bit worried about there being a significant difference between the two dampers and this messing up the suspension.
Is this normal?
507VBH
Re: New front dampers not the same!
Postby CHRIS in MARGATE » Wed May 18, 2016 10:49 pm
I'm pretty certain it is the resistance of the pull on the damper and not the push that is important.
Postby Warkton Tornado No.1 » Thu May 19, 2016 12:13 am
I agree with Chris that the damping is on the rebound & the primary function, but, all the same, I’d be looking for ‘balance’ & it would be something you would expect from new kit.
I would ask Scootopia what they think. They have a good reputation & I’m sure they will react accordingly.
Postby Scooterslag » Thu May 19, 2016 6:08 pm
My scootopia dampers have been on my scoot for nearly a year now, never noticed any such issues, maybe you've got a duff pair, give them a call, they're really sound blokes. Paul
Postby 507VBH » Fri May 20, 2016 6:51 am
Scootopia stuff is normally pretty good so I will give them a ring.
507VBH
Postby 507VBH » Mon May 23, 2016 7:28 pm
I happened to be at Urban Scooters in Birmingham and showed the dampers to Danny (the Vespa man). He said one is knackered.
Back to Scootopia now!
507VBH
