petrol tank sealant
petrol tank sealant
Postby bluebob » Tue May 17, 2016 7:18 pm
can anyone recommend a brand of tank sealer.and the best type of place to to get it.eg:do car accessory shops supply it.
bluebob
Re: petrol tank sealant
Postby mr series 2 » Tue May 17, 2016 7:41 pm
http://www.tankcareproducts.co.uk/index.htm
Had this in for three years still perfect
mr series 2
Postby Rich Oswald » Tue May 17, 2016 8:08 pm
mr series 2 wrote:http://www.tankcareproducts.co.uk/index.htm
+1
Postby sunrisemac » Tue May 17, 2016 8:09 pm
This works well, I've used it on quite a few race car tanks and my GP with total success
http://www.frost.co.uk/por15-fuel-tank-sealers.html
sunrisemac
Postby Storkfoot » Tue May 17, 2016 9:32 pm
I've used the tankcareproducts on a couple of tanks that have needed welding, one Diablo for a Lambretta and an original Vespa Rally one. I thoroughly cleaned them, obviously, before welding and only used the sealant because they were being welded. If you meticulously follow the instructions and ensure you buy enough of the sealant, the product is very good.
If the tank is generally sound and just rusty and/or covered in oily sludge, personally, I have just followed this:
http://www.realclassic.co.uk/techfiles/ ... moval.html
It works a treat and is cheap (I have done this twice too). Do be careful though. You're dealing with nasty stuff
Postby Chadley » Tue May 17, 2016 10:02 pm
+2.5
Chadley
Postby Tractorman » Wed May 18, 2016 8:49 am
sunrisemac wrote:This works well, I've used it on quite a few race car tanks and my GP with total success
This good stuff I have sealed my two tanks without any problems.
Postby sherpadean » Wed May 18, 2016 8:04 pm
I've used PQR15 from Frost auto restorations .....cracking stuff....in the tank for 2 years now without problems......
sherpadean
Postby bluebob » Wed May 18, 2016 8:52 pm
thanks for replies.sounds like two good products there.my tank is not in bad nick,give it the nuts and bolts treatment and refitted.just getting some small rusty bits still coming out,and a few passing the inline filter.as its a new build I don't want to take chances.probably describe it as light surface rust at worst.just looking at one of the websites which describes de-rust and de-ox ? treatment before sealing.i want to do it right but this sounds a bit ott.any thoughts please?
bluebob
Postby mr series 2 » Wed May 18, 2016 9:39 pm
I've done quite a few tanks now & always cleaned them by using sharp Flint type stones & thinners give the tank a good shaking then remove the stones & thinners and clean out with fresh clean thinners then dry with compressed air or just put it in the sun
mr series 2
Postby Tractorman » Wed May 18, 2016 11:05 pm
mr series 2 wrote:I've done quite a few tanks now & always cleaned them by using sharp Flint type stones & thinners give the tank a good shaking then remove the stones & thinners and clean out with fresh clean thinners then dry with compressed air or just put it in the sun
If you are more urban based you could old nuts and bolts or ball bearings. Diesel or paraffin is also good.
