dry fit pics ???
dry fit pics ???
Postby daniel whiteley » Sun May 15, 2016 4:02 pm
long shot but does anybody have a good close up pic of a dry fit they have done of the front mudguard to the legshield right at the bottom ??? im just repairing mine as it was damaged on one side but i have dry fitted them and there is a gap of around 5-7 mm right at the bottom of the mudguard to the underside of the legshield , i can beat it into shape no problem as its what i do for a living(panelbeater) just want to check first on what other people think , sorry i dont have a pic
daniel whiteley
Re: dry fit pics ???
Postby Dimitrios_231 » Sun May 15, 2016 4:57 pm
Dry fitting.
Dimitrios_231
Postby daniel whiteley » Sun May 15, 2016 6:54 pm
cheers for that Dimitrios_231 i just couldnt understand it as only one side had been damaged which i had mad a piece and welded in but the good side had a massive gap !!! even tho they are all the original panels (i didnt know how they fit before stripped down as i bought it in bits)
only photo ive got of mudguard on , not very good
this is what i had to do to leggies as some dodgy italian had properly bodged them
the edge was knackered so the part what didnt fall off was cut off
then made a new edge , not the easiest without a bender (only bodyshop ive ever worked in without one but not called for on these new cars i guess)
the leggies were still that stretched after spending ages shrinking the bottom i ended up making
so that done the front mudguard and hence my problem
daniel whiteley
Postby Dimitrios_231 » Sun May 15, 2016 8:48 pm
I admire your skills,very tidy job,
the mudguard pic doesn't look bad.
Dimitrios_231
Postby daniel whiteley » Mon May 16, 2016 5:59 am
Thank you , yeah the mudguard fits nice down the side it's just the last inch underneath where there is a big gap
daniel whiteley
Postby Toddy » Mon May 16, 2016 6:13 am
Dimitrios_231 wrote:I admire your skills,very tidy job,
Agree great bit of work :D
Postby nickw » Mon May 16, 2016 12:04 pm
Can't tell from your photo but it might fit better with the rubber mud guard gasket. Good bit of work on the legshield.
nickw
Postby Warkton Tornado No.1 » Mon May 16, 2016 1:39 pm
Hey Daniel.
I don’t possess your skills but when I built my last road going Lambretta from the mishmash of parts that I had acquired, I encountered the same problem but by then, all parts had been fully painted. Hindsight & all that, but the parts must have ‘moved’ during the blasting process so for dry builds to be of any value, they need to be done after any process likely to compromise the fit. You would no doubt be aware of that! :mrgreen:
I reasoned that I could only try & fit the bottom of the mudguard first using huge penny washers & gradually try & pull the top end of the mudguard in toward the legshields.
Of course, it ended up as a compromise as the holes started to pull through on the inside of the legshields…. :roll:
Anyway, undoubtedly you will get it all sorted but I’d ask that you please carry on showing us such fantastic work & detail in this Forum somewhere as it is so much more interesting than just seeing the finished article in ‘Show your ride’
Good Luck with the build & I hope to see much more. :)
Postby daniel whiteley » Mon May 16, 2016 6:39 pm
thanks for your replies chaps , i enjoy fettling with things i guess its what makes me good at my job (i hope) ive rebuilt bikes before and restored a few cars over the years and even a couple of vans in all the bodyshops ive worked but ive never actually owned and restored anything of my own (apart from my bmx's) never mind a lambretta even tho ive worked on a few in the past for friends and such so its just something new to me hence me not knowing how things should fit seeing as it came to me in a box in pieces !!
anyways i think someone must have sat on these leggies when they took them off as the gaps are shocking !!! or its just me working to the tolerences of car gaps ha ha
so got a couple of pics today in my dinner
this is the side i made the piece for and welded in , had a little tickle with the hammer and now its not bad
this is the other side after a good 5 mins tapping about , still a bit to go i think
the next question is , how should the horncast dry fit because the gaps on mine especially at the top i could reach in and steal the wiring loom !!
are the 2 holes for the top screws of horncast supposed to be recessed in to allow it to pull closer or should they be flat to the panel ???
cheers
daniel whiteley
Postby Dimitrios_231 » Mon May 16, 2016 9:21 pm
Recessed in ;)
Dimitrios_231
Postby johnnyXS » Wed May 18, 2016 11:03 am
nice work ;) Once its painted it will be a completely invisible repair. So much more satisfying than bodyfilla
johnnyXS
Postby kennystag » Wed May 18, 2016 12:38 pm
What a cracking job.
Stag
8-)
kennystag
Postby daniel whiteley » Wed May 18, 2016 7:35 pm
cheers for the kind comments chaps , jonnyxs yes getting a good metal finish is nice but it will still have a small skim here and there to finish but it wont be lathered in it , dimitros do you have a picture of the legshield top hole with the horncast not fitted so i can see how the hole is recessed so i can copy it ????? your pictures have helped alot , just very busy at work so only getting the odd 5 mins here and there
daniel whiteley
Postby Dimitrios_231 » Wed May 18, 2016 8:02 pm
:D
These pics are from remade legshields that I have never used,the idea is similar.
The picured legshields need to get cut half cm each side to perfectly fit on the frame,I might sell cheap in the future if anyone is interested.
Dimitrios_231
Postby daniel whiteley » Wed May 18, 2016 8:06 pm
cheers for that dimitros thats easy enough to do i will fettle a tool from something to press it in
daniel whiteley
Postby Dimitrios_231 » Wed May 18, 2016 8:18 pm
Dimitrios_231
Postby daniel whiteley » Thu May 19, 2016 8:19 pm
so ... i managed to fettle a little something to put the recess in , a few washers and a nut and bolt later
test run on some scrap , bit softer then the old italian steel but good to try on
and then grind to fit inside the legshield
so thats the horncast sitting better , does that look about right dimitros ????
daniel whiteley
Postby johnnyXS » Fri May 20, 2016 12:04 am
showoff ! :lol:
nice bit of ingenuity
johnnyXS
Postby peejay » Fri May 20, 2016 12:23 am
great work Daniel, would be a good idea to now try the rubber trim between these three items and nip up.
Postby daniel whiteley » Fri May 20, 2016 8:58 pm
johnnyXS wrote:showoff ! :lol:
errrm thanks :lol:
you pick up tricks and litle things when you have been doing jobs like this for the last 20 odd years ;)
anybody tell me what vehicle it is ?? :?:
daniel whiteley
