GT186 / Series 2 / PHBH 30 / TSR Evo - Sudden Rough Running
Postby Donnie » Thu May 12, 2016 7:38 pm
So, been going fine since I built this engine, other than my burning the clutch and having to redo that etc.
So, going fine, done the jetting running well other than a soft seize where I tweaked the jetting again and no problems, if anything slightly rich until opening it right up.
However, after a few weeks of no issues Ive suddenly developed a low speed bweaaaahhhhhhburbleyburble which i estimate at about a quarter throttle, like its missing a beat but open her up and it dissappears.
Now, that morning id put some petrol in from a can stored in the shed for a week or so and assumed it was that.
Actions so far:
Drained and refilled with fresh fuel and oil - no difference.
Thinking it's a load issue changed the cdi, lead, ht cap and spark plug - no difference.
left kill switch unplugged thinking a loose earth - no difference
Just stripped, cleaned (didnt need it) carb and rebuilt it and now wondering what's left??
I can only think its worth restrobing the timing or / checking reed petals?
Anyone got any other thoughts before I delve into that?
Donnie
Re: GT186 / Series 2 / PHBH 30 / TSR Evo - Sudden Rough Run
Postby MickYork » Thu May 12, 2016 8:08 pm
Stator/pick up ?
Postby Donnie » Thu May 12, 2016 8:14 pm
Ah good point, missed that was thinking too far ahead! I can do that with only disconnecting a couple of wires! Back in 5
Donnie
Postby Donnie » Thu May 12, 2016 8:22 pm
Done it, white to mag housing - short circuit as it should
white to red (pickup expected reading 95-120ohms) reads 94-95 so on lower end of normal and same as when built.
white to green (LT Coil expected reading 450-540ohms) reads 455 and again same as when built.
Bugger, not that either then.
I cant see it being the reed petals as surely it would simply get worse on acceleration?
Donnie
Postby MickYork » Thu May 12, 2016 9:52 pm
once had a pick up that was loose. only caused a problem in a certain rev' band.
Slim chance but worth checking.
Postby coaster » Thu May 12, 2016 10:11 pm
Reeds ok? and seeing as you have had a seize, what's the compression like? just wondering if a ring has got stuck in its groove?
Postby Donnie » Thu May 12, 2016 10:17 pm
MickYork wrote:once had a pick up that was loose. only caused a problem in a certain rev' band.
Slim but never know so will have to physically check it after tomorrows shift.
Donnie
Postby Donnie » Thu May 12, 2016 10:18 pm
coaster wrote:Reeds ok? and seeing as you have had a seize, what's the compression like? just wondering if a ring has got stuck in its groove?
compression never altered and its been running spot for a few weeks since that happened and suddenly its now misbehaving. Ill check the reeds though
Donnie
Postby Meds » Fri May 13, 2016 9:00 am
Is your choke cable being tensioned as the engine swings.
Mine was rubbing on the toolbox and causing the choke to pop on slightly
It was only evident when pulling away.
I found it by accident, noticed the rubbing on the toolbox, stuffed in a flip choke and he problem disappeared.
Meds
Postby burnside » Fri May 13, 2016 1:09 pm
Did you double up the reeds? Rich T recommends this if using an expansion on the 186 kit
burnside
Postby Toddy » Fri May 13, 2016 3:03 pm
The stator can be faulty under load , usually it breaks down completely then after cooling down will re start so can't be checked when standing , just a thought
Postby Wack » Fri May 13, 2016 7:56 pm
Put some marks on your throttle grip and switch housing then ride it and see where the bad spot is.Then try dropping the needle one notch to see if the rough spot clears,it may be a worn needle and atomiser.
Postby johnnyjarvis » Fri May 13, 2016 8:58 pm
What Wack said.Best £20 Ive ever spend on my scooter.
Had the same problem a couple of years ago. Changed and tested everything and finally bought a new atomiser and needle.
Smoother than a smooth thing.
johnnyjarvis
Postby Donnie » Fri May 13, 2016 9:09 pm
Meds wrote:Is your choke cable being tensioned as the engine swings.
Nope not that either, checked it.
Donnie
Postby Donnie » Fri May 13, 2016 9:11 pm
burnside wrote:Did you double up the reeds? Rich T recommends this if using an expansion on the 186 kit
I haven't actually but IF that was the cause why would it only now be an issue after several hundred miles?
Donnie
Postby Donnie » Fri May 13, 2016 9:13 pm
Toddy wrote:The stator can be faulty under load , usually it breaks down completely then after cooling down will re start so can't be checked when standing , just a thought
That's usually only the old "wont restart when hot, but does from cold" scenario isn't it? ie the heat expands the cracked wire and it stays "broken" until it's cooled?
Donnie
Wack wrote:Put some marks on your throttle grip and switch housing then ride it and see where the bad spot is.Then try dropping the needle one notch to see if the rough spot clears,it may be a worn needle and atomiser.
It's not, new needle and atomiser in there and new slide too.
Donnie
Postby Toddy » Fri May 13, 2016 9:27 pm
It is but can cause similar symptoms to yours
Postby Donnie » Fri May 13, 2016 10:21 pm
Hmm worth bearing in mind, but this is doing it straight from cold too?
Just had the flywheel off to physically check stator, nothing loose, all wires look good, almost hoped there would be something broken and obvious.
Next step is the reeds i guess
Donnie
Postby Adam_Winstone » Fri May 13, 2016 10:26 pm
Never trust a stator, which can appear fine and give correct readings, but reeds are a good shout too.
Good luck getting to the bottom of it.
