Cam Lam carb jetting chart
Postby Revvers » Thu May 12, 2016 3:27 pm
Hello. I've been looking at the cam lam chart as a basis to rejet my Mugello 186 set up. It lists jetting for phbh 26mm carbs and 30mm. I have a 28mm, is there a formula whereby I can work out where I need to be using the 26/30 settings??
Revvers
Re: Cam Lam carb jetting chart
Postby missing lynx » Thu May 12, 2016 10:27 pm
try the scooterotica site they have a section were people post actual set ups
Postby CHRIS in MARGATE » Fri May 13, 2016 6:17 am
Bristol Lambretta Club site has a very good jetting section.
Postby MickYork » Fri May 13, 2016 9:52 am
Probably not a lot of difference between the 28 and 30. Set up as the 30 and worst scenario is you'll be too rich....better safe than sorry.
Postby Kev Fox » Sun May 15, 2016 7:34 pm
Myself and 2 buddies are running 186 Mugello's with 28mm PHBH Dellorto Carbs with 50 Pilot and 105 main.
Kev Fox
