Speedo Woes With Outboard Disk
Postby plantphoto » Wed May 04, 2016 7:29 pm
Purchased a GP225 TS1 with Hydraulic outboard disk (not sure of make).
The speedo was not working so purchased the correct drive kit (normal GP ones don't work) and it worked fine for 10 mins !
It's all connected but still not working and wondered if the actual inner speedo cable might be different too.
Any ideas tips or advise would be appreciated.
Simon
plantphoto
Re: Speedo Woes With Outboard Disk
Postby Toddy » Thu May 05, 2016 6:16 am
Simon a picture may help so people can see what type it is
Postby CHRIS in MARGATE » Thu May 05, 2016 6:50 am
Have you got a broken end you can push in and see if it rotates. Sometimes need to trim outer back. I flattened my drive spindle just s tad to sit the cable in tighter.
Postby plantphoto » Thu May 05, 2016 2:02 pm
This is the disk not sure of make.
It works until I brake then seems jump out.
Wonder if inner cable is longer for these if drive/ worm are different.
plantphoto
Postby CHRIS in MARGATE » Fri May 06, 2016 7:28 am
Looks same as mine. ScootRS. Took me some time to get it right but it's spot on. I use a drill in reverse to check the speedo. Connect inner cable and support drill on something. I was a while verifying why both ends turned but no speedo until I cut outer and fitted new olive.
Postby plantphoto » Fri May 06, 2016 8:47 am
Thanks same thing I discovered yesterday ! Parts ordered so hopefully sorted.
I hate not having a speedo despite it may be 35mph out !
Cheers Guys
plantphoto
