wheel bolts
wheel bolts
Postby baroda26 » Mon May 02, 2016 3:13 pm
I have a spare rear hub its looks good but I decided to use tubeless and needed the extended bolts
Took wheel bolts out a bit of a job then found the threads were 8mm not 10mm has anyone seen this know anything about it the hub is useless as it is i think
Adviceneeded
Cheers Terry
baroda26
Re: wheel bolts
Postby ToBoldlyGo » Mon May 02, 2016 8:25 pm
Would it be possible to tap the threads out to 10mm?
Re: wheel bolts
Postby baroda26 » Mon May 02, 2016 9:03 pm
I suspect yes
drill out and reap the hub simple to do LH thread though and i will need a good drill
May look at the metal on the lugs and see if there is enough in them compare them with other 2 I have
Cheers terry
baroda26
Re: wheel bolts
Postby baroda26 » Mon May 02, 2016 9:28 pm
I did what your name said TOBOLDLYGO
Measured and compared the other 2 drums all LUG measurements the same
Drilled out to 9mm tap size for 10mmx1mm
Tapped 10mmx1mm Lefthand thread fitted new extended bolts for the tubeless alloys
First rate advice done in less than 30 minutes
Cheers Terry
baroda26
Re: wheel bolts
Postby ToBoldlyGo » Mon May 02, 2016 9:35 pm
That was lucky. Glad it worked. :)
Re: wheel bolts
Postby corrado » Wed May 04, 2016 2:56 pm
The only rear hubs I've come across with different studs are Ramp hubs. Off top of my head I can't remember if the studs were bigger or smaller. Easy to spot by looking inside to find RAMP embossed [or ground off :roll: ]. Ramp are best avoided.
corrado
Re: wheel bolts
Postby burnside » Thu May 05, 2016 12:05 pm
corrado wrote:The only rear hubs I've come across with different studs are Ramp hubs. Off top of my head I can't remember if the studs were bigger or smaller. Easy to spot by looking inside to find RAMP embossed [or ground off :roll: ]. Ramp are best avoided.
Good point and well worth re-emphasising
burnside
Users browsing this forum: No registered users and 92 guests
