Indicator switch
Indicator switch
Postby Knowledge » Sun Apr 24, 2016 10:46 pm
Am I correct in thinking that there is a version of the SIII trapezium shaped handlebar switch that incorporates an indicator switch? If so, was it a factory item (Indian?) or a special part manufactured for a dealer?
Are such switches still available?
If not, has anyone got one?
Re: Indicator switch
Postby CrocodileJock » Mon Apr 25, 2016 10:20 am
My Serveta had a indicator rocker switch on the handlebars… ugly black plastic box bolted on to the alloy.
CrocodileJock
Postby Donnie » Mon Apr 25, 2016 11:30 am
This is the servetta item referred to but will be no good to Martin
http://www.ebay.co.uk/itm/Lambretta-Ind ... SwD0lUlBja
Martin is right that the indians did a trapezoid switch converted to the indicator switching so you need a key switch for your lights too assuming you don't already have one.
Scooter restos do them though Martin at http://www.scooterrestorations.com/lamb ... al-shaped/
worth dropping them an email to confirm though.
Donnie
Postby mickey c » Mon Apr 25, 2016 11:44 pm
I've had a couple of those of Scooter restorations, not sure what model SIL, Vijay etc it was used on but seems standard and works well without having to attach a seperate indicator switch. Bit of a squeeze getting all the wires through the headset and they are not very supple - I dropped and broke my wife's hair dryer warming the outer plastic sleeve - she was thrilled it helped get the harness through!
mickey c
Postby Knowledge » Tue Apr 26, 2016 12:33 pm
So Mickey, was it a special switch, designed for indicators, or a standard one?
Postby mickey c » Tue Apr 26, 2016 5:59 pm
Don't quote me but I think it's a standard factory switch off some (unknown to me) Indian model. It looks just like an Li switch but some newer touches such as a picture of a horn on the button & the obvious relevant bit is side light / headlight switch does the indicators.
mickey c
