Quick question re-Kelvinator frame.
Postby kevspeed » Thu Apr 21, 2016 8:10 pm
Been offered a 'Kelvinator' frame.
Will the standard GP bodywork/panels/forks fit without hassle?
kevspeed
Re: Quick question re-Kelvinator frame.
Postby terryj » Thu Apr 21, 2016 8:27 pm
dont know about the frame but the engine is a right mix up had a scrap one and the holes for the gear box endplate dont line up with any other engine same with the chaincase side mag flange is also odd ball size bit of a bonus its an li 150 gear bos as per number of teeth just need to measure diameters bet it only works with its own xmas tree
one or two on here have kelvinator scoots so you should find out soon
terryj
Postby Mark esq » Thu Apr 21, 2016 9:25 pm
What's a Kelvinator scooter
Mark esq
Postby terryj » Thu Apr 21, 2016 9:30 pm
made in india same company as the fridges i believe
http://www.lambrettaspares.com/info/art ... -+267.html
terryj
Postby kennystag » Fri Apr 22, 2016 10:05 am
What engine was fitted to them.
Stag
kennystag
Postby Digger » Fri Apr 22, 2016 10:46 am
Digger
Postby rossclark » Fri Apr 22, 2016 8:32 pm
I thought I read somewhere that the engine was a bit of a mishmash of API parts.
Postby Jim Rose » Sat Apr 23, 2016 10:16 am
A few Vespa bits have snuck in to the front end I see. As said earlier an ugly brute
Jim Rose
Postby terryj » Sun Apr 24, 2016 10:53 am
i think a lot if not all of the engine was made by kelvinator
the mag housing uses an li bearing but without the spacer ring
the holes in the gear box endplate do not line up with any other make of engine
the same with the side case all the holes are slightly out of line
the gear box has the same teeth numbers as an li 150 havent checked the dias yet
top end is 150 and point ignition
will have a look at the carb and see what that is not a jetex type
terryj
Postby Tinman » Mon Apr 25, 2016 11:46 pm
A chap in our club has one,the loop is longer towards the rear end so the side panels are longer too.
It's not been altered as far as we could see and Gp side panels are about an inch short.
Tinman
