Stand Spring Length
Stand Spring Length
Postby Paul_from_Thornbury » Wed Apr 20, 2016 8:14 pm
Anyone know what the correct length of a stand Spring is, I've got two aftermarket ones which are slightly long as my stand droops and if I pull the stand up under the running boards with my heel the spring pops off.
From outside of loop to outside of loop mine are 110mm long.
Paul_from_Thornbury
Re: Stand Spring Length
Postby Toddy » Thu Apr 21, 2016 6:22 am
Are you sure the two main Fixing bolts on your stand are not loose as this would cause the same issue as spring length ?
Postby Dimitrios_231 » Thu Apr 21, 2016 7:52 am
I don't know the correct length,sorry,the length can be different and it plays a major role.
I usually shop with a spring in my hand to compare.
These 3 springs are supposed to be from the same manufacturer.
Dimitrios_231
Postby Paul_from_Thornbury » Thu Apr 21, 2016 2:37 pm
Bolts are all tight
Paul_from_Thornbury
Postby Paul_from_Thornbury » Thu Apr 21, 2016 2:38 pm
What are the lengths of the longest and shortest springs in the photos?
Paul_from_Thornbury
Postby Dimitrios_231 » Thu Apr 21, 2016 3:48 pm
Τhis pic was taken a couple of years ago,
I can't remember :shock: :) ,
I'll check if I have any notes on my logbook,
sometimes I write down on paper some anorak pretty useless things ;)
Dimitrios_231
Postby Tony Hart » Thu Apr 21, 2016 5:10 pm
Hi Paul
I just measured one that I took off my latest project and it is 105mm from outside loop to outside loop
Tony
Tony Hart
Postby MK Monty » Thu Apr 21, 2016 5:17 pm
I'm sure series 1/2 are not the same length as series 3. But I don't know which is longer. Personally I steer clear of the stainless ones rather have a bit of rust.
MK Monty
Postby Tony Hart » Thu Apr 21, 2016 5:24 pm
MK Monty wrote:I'm sure series 1/2 are not the same length as series 3. But I don't know which is longer. Personally I steer clear of the stainless ones rather have a bit of rust.
The rusty one I measured came off a rusty Spanish S2. Most dealers I use don't have different springs listed for S1/2 or 3. Scooter Restorations does have a slightly longer one listed for late Indian GPs
Tony
Tony Hart
Postby Dimitrios_231 » Thu Apr 21, 2016 7:28 pm
Measured two used.
Left one 106.5.right 105.2 from outside loop to outside loop.
I always keep the left one as a spare in the toolbox .
Dimitrios_231
Postby hullygully » Sat Apr 23, 2016 10:50 am
also depends on the correct welded position of the stand cross member & if your using an Indian stand as I've got some stainless steel ones where they're defo welded in wrong position grrrrrrrrr :twisted:
