Keeps reving
Keeps reving
Postby Charliebubble47 » Sat Apr 09, 2016 1:14 pm
Just started up "the bane of my life" and it's ticking over nicely then all of a sudden it's starts to over rev upto the point the engine is screaming
Switched it off, checked the throttle and it's in the low rev position, choke is off kicked it over same thing happened
It's a 185, with a 22mm jetex and a clubman exhaust never happened before, had fuel problems before but changed the tank, tap, lines and cleaned out the carb and all was ok
Any ideas gents please
Charliebubble47
Re: Keeps reving
Postby MickYork » Sat Apr 09, 2016 1:17 pm
Sounds like an air leak ?
Check round the carb' area first and make sure everything is "air tight".
A leak testing kit is a good investment, I think Darrel Taylor sells them (he's on facebook).
just another thought....take the bellows off and check the slides closed......
Re: Keeps reving
Postby Warkton Tornado No.1 » Sat Apr 09, 2016 3:54 pm
If you can, disconnect the throttle cable @ the carb & start so that you're eliminating any shenanigans that might occur through routing et cetera.
Then, if the thing does it again, you know it's not the control side, though if the float is sticking so that fuel runs out, it can go as you describe.
Unfortunately, it does sound as already mentioned, like an air leak.
Re: Keeps reving
Postby HxPaul » Sat Apr 09, 2016 5:34 pm
Check that the outer throttle cable hasn't dropped out of the recess in the headset clamp.
Re: Keeps reving
Postby Scooterlam » Sun Apr 10, 2016 1:21 pm
check your carb bowl is filling.
turn fuel on leave for a minute or so turn off disconnect fuel pipe kick her up and if symtoms are the same slow filling could be your problem
Scooterlam
Re: Keeps reving
Postby Rich Oswald » Mon Apr 11, 2016 8:15 pm
HxPaul wrote:Check that the outer throttle cable hasn't dropped out of the recess in the headset clamp.
This is the first thing I would check!
Re: Keeps reving
Postby Adam_Winstone » Mon Apr 11, 2016 8:20 pm
Massive air leak, e.g. failed inlet gasket or manifold tightening on studs, rather than seat face, etc...?
Re: Keeps reving
Postby byron » Mon Apr 11, 2016 9:52 pm
or blocked idle jet...?
byron
Re: Keeps reving
Postby bigbthesoulman » Thu Apr 14, 2016 12:41 pm
sounds like air leak,
bigbthesoulman
Re: Keeps reving
Postby Charliebubble47 » Sun Sep 11, 2016 12:23 am
Sorry it's took me so long to update but been out of action getting a new hip
So I carried out all the checks, tightened up everything that could be tightened up, renewed the inlet manifold gasket and
Renewed the air bellows as I found a split in them.
Hey presto it fires up and ticks over for a full twenty minutes without any problems, I should have done it methodically and identified the problem but was in too much of a hurry
Can I just say thanks for all tips and pointers they were invaluable
CB
Charliebubble47
