by Charliebubble47 » Fri Apr 08, 2016 8:05 pm
Whats a good quality side case engine gasket for a LI125? And were would I get it from
Thanks in advance
CB
Charliebubble47
by petemaisey » Fri Apr 08, 2016 8:47 pm
It seems to be a rule that it's more economic to by a gasket set. I have found any type to be fine. I always grease both sides of the gasket. The helps it seal and it will release without tearing so can be re used. Handy if you are midway through your trans Siberia charity run.
Pete
petemaisey
by Warkton Tornado No.1 » Fri Apr 08, 2016 8:56 pm
I buy the thick gaskets like CamLam produce. Four years on the road scooter & the same type has been on a racing machine for even more years with constant stripdowns with no sign of damage. They are so much easier to deal with rather than those floaty paper gaskets that can't decide whether to stay on the crankcase or the cover.
As the guy said, grease liberally both sides but I would also advocate that you use studs if you can.
by JETEX » Sat Apr 09, 2016 10:38 pm
A dealer near me has those thick cork type gaskets. I think they were about £4 each.
JETEX
by Charliebubble47 » Sun Apr 10, 2016 11:57 am
JETEX wrote:A dealer near me has those thick cork type gaskets. I think they were about £4 each.
What dealer would that be please?
Charliebubble47
by HxPaul » Sun Apr 10, 2016 4:05 pm
Be carefull with those cork gaskets,if the gaskets are to thick it could effect your clutch action.
by JETEX » Sun Apr 10, 2016 10:44 pm
Charliebubble47 wrote:JETEX wrote:A dealer near me has those thick cork type gaskets. I think they were about £4 each.
PM sent
JETEX
by EddieStone » Mon Apr 11, 2016 11:47 am
I've always greased gaskets and I've never had one come off in one piece.
EddieStone
