by lammydave » Fri Apr 08, 2016 5:33 pm
So if I'm having to rev up and slip the clutch when pulling away, instead of just being able to twist and let the clutch out, what should I be looking to do, jetting-wise??
186 mugello
28 phbh
remote filter
JL3
lammydave
by MickYork » Fri Apr 08, 2016 5:45 pm
Lean the mixture (smaller jets). What's it like without the filter and what difference does the choke make ?
Or check your gearing. Are you "too tall" for your set-up ?
Or what's your timing set at ? are you too far retarded ?
by lammydave » Fri Apr 08, 2016 6:31 pm
MickYork wrote:Lean the mixture (smaller jets). What's it like without the filter and what difference does the choke make ?
gearing maybe an issue... it's an SX200 box
timing at 19 degrees
haven't tried it without a filter... give that one a go, does seem to be running rich....
lammydave
by ToBoldlyGo » Sat Apr 09, 2016 6:13 pm
It does sound as if it's over jetted.
