Tv175 series 2 barrel
Postby Patricks3179 » Wed Apr 06, 2016 3:17 pm
Hi could anyone recommend a standard tv175 series 2 set up, I know it's going to be impossible to find a 175 barrel are there any other decent barrels or is the only option to rebore a 150
Patricks3179
Re: Tv175 series 2 barrel
Postby TV Times 2 » Thu Apr 07, 2016 9:12 pm
When sorting out the problems with my S3 my mate bought a 175 kit before I had chance to source one and along with a new TV175 piston it worked fine.
I was going to look for something other than Indian for better quality but it's OK.
TV Times 2
Postby Patricks3179 » Sat Apr 09, 2016 1:09 pm
Thanks for the reply yeah think I'll try one of the Indian kits. Anyone know what the beedspeed or af rayspeed 175 kits are like ?
Patricks3179
Postby phil99 » Mon Apr 11, 2016 7:35 am
Hi Patricks I have a A F Rayspeed Ali 175 kit on a 150 series 2, done 3K. miles with no problems including last years coast 2 coast both ways.
The Ali barrel has an iron liner, running in advice from A F is 1K miles.
regards phil
phil99
Postby Patricks3179 » Mon Apr 11, 2016 4:09 pm
Thanks phill I'm going to e mail af rayspeed , what carb and exhuast did you set yours up with ? Thanks patrick
Patricks3179
Postby phil99 » Mon Apr 11, 2016 9:11 pm
Hi Patrick when you email A F Rayspeed ask what carb and exhaust they would recomend for the performance you want.
my series 2 has 28mm phbh delorto ramair filter 42mm A F clubman,they were on the scoot when i purchased it 4 years ago.
Good luck with your choice of kit keep us posted. phil
phil99
Postby Patricks3179 » Tue Apr 12, 2016 6:31 pm
Thanks phill I'd like to keep a Dellorto 20 mm carb on and try keep it pretty standard will post a blog when i start restoring it thanks for your help!!
Patricks3179
Postby kennystag » Wed Apr 13, 2016 7:03 am
Hi,
I got my 175 conversion top end kit from Jason at Saxon scooters. I am really happy with the kit, if you talk to him tell him I mentioned the kit, also check his feedback for the kits. eBay item number 281914735725 .
Stag
kennystag
Postby Patricks3179 » Wed Apr 13, 2016 7:59 pm
Thanks stag ,, did the kits take much setting up and what's the quality like , how long running in thanks patrick
Patricks3179
Postby kennystag » Wed Apr 13, 2016 8:16 pm
Hi Patrick,
The Bore/Piston Clearance has been professionally checked/honed to 0.003. I checked it all out and was spot on, quality is good. Running in about 300 to 500 miles. Hi is getting more kits in stock soon when I spook to him. I fully recommend this kit, so far so good, very happy.
Stag
:D
kennystag
Postby kennystag » Fri Apr 15, 2016 4:08 pm
H Patrick,
I see Jason has the 175 kits back in stock.
Stag
http://www.ebay.co.uk/itm/Lambretta-175 ... SwksVTzn0h
kennystag
Postby Patricks3179 » Sun Apr 17, 2016 7:58 pm
Thanks stag , got married this weekend so been busy I'll drop him a message and be sure to mention you !!
Patricks3179
Postby kennystag » Mon Apr 18, 2016 8:54 am
Hi Patrick,
Congratulations on your marriage. All the best for the future. Going back to the kit a am very happy with it,so far so good as they say. I fitted another carb, Scootopia SH2/22 22mm. What a big difference the hole set up has made.
Good Luck
Stag
kennystag
Postby 507VBH » Wed Apr 20, 2016 6:56 am
What sort of bhp do these kits give?
507VBH
Postby kennystag » Wed Apr 20, 2016 7:18 am
Hi Patrick,
The best thing to do is contact Jason @ saxsonscooters, he will give you the full speck, and answer all your questions on the kit.
Stag
kennystag
Postby Jim Rose » Wed Apr 20, 2016 7:18 am
I've been running one of the AF 175 conversion kits for about 10 years it's been reliable all that time. I've got it on a 30mm Delorto with a PM. The kit just bolted on with no port timing issues. The last big trip i've done on that motor was to Austria last year 700 miles in two days. I had it Dyno'd last year before the euro and it was siting at 12bhp after the Dyno I did open up the exhaust port to increase the top speed. My sat nav was sitting at 65mph when I was overtaking lorries on the auto barn
Jim Rose
Postby kennystag » Wed Apr 20, 2016 7:46 am
Sorry Patrick,
Try this link, for some reason that other link is wrong.
Stag
kennystag
Postby Patricks3179 » Mon Apr 25, 2016 12:42 pm
Thanks for the links kenny not been back from honeymoon long , think I might be luck trying to find a tv175 barrel some being sold on eBay at the minute .
Patricks3179
Postby Patricks3179 » Mon Apr 25, 2016 12:45 pm
eBay 262403521619 could be worth a chance!!
Patricks3179
Postby kennystag » Mon Apr 25, 2016 1:30 pm
Hi Patrick,
If it is not to bad it may clean up with honing. its a chance you take buying secondhand. If you get it cheep enough go for it.
Kenny
kennystag
