STRIPPED EXHAUST STUD HOLE - IDEAS
Postby Covboy » Fri Mar 18, 2016 11:36 am
Hi All
Just noticed on my LI that the top exhaust casing stud is missing. On closer examination the casing thread is stripped and I can't get a new stud to bite.
My question: - is there any easy repair that doesn't involve taking out the engine, welding or specialist tools? i.e. oversized stud etc
Re: STRIPPED EXHAUST STUD HOLE - IDEAS
Postby Scooter Paul » Fri Mar 18, 2016 12:24 pm
MBD list a stepped repair stud, MBP 0392 @£5.65p. You will need to drill and tap to 10mm but this could be done in situ. Remove footboard and silencer and chaincase.
Paul.
Scooter Paul
Postby steve t » Fri Mar 18, 2016 1:46 pm
M8 helicoil kit you will be able to do it In situ not that expensive of eBay
steve t
Postby Warkton Tornado No.1 » Fri Mar 18, 2016 1:50 pm
Helicoil back to M8.
I have the kit & Coventry is not a million miles away from Warkton.
But you may be able to borrow the kit more locally.
I hope that helps.
Postby Covboy » Fri Mar 18, 2016 2:39 pm
Thanks chaps and Thank you WT#1 for your kind offer : - I have just bought a 131 piece kit - M5 - M12 for £25.99 as I need to repair a horncase too....
Steve
