Silme GP seat
Silme GP seat
Postby Storkfoot » Thu Mar 17, 2016 12:02 pm
I have a Silme seat that came without the catch that attaches to the frame. I know that originally the catches were the same sort of ones that the Giuliari has ie looks like a shoe horn has been soldered on a plate.
I bought a new catch but it is the best part of an inch out, so to catch properly the "shoe horn" part needs to be more central.
Before I take the grinder to the "shoe horn" does anyone know whether the Silme seat is materially different to the Giuliari?
ps. Initially I thought the issue was that the seat frame was bent, however, it isn't.
Re: Silme GP seat
Postby Covboy » Fri Mar 18, 2016 11:43 am
Hi - I had real fun trying to find a catch for my guillari seat. I must have bought 3 until I found one that actually fitted...is yours like this : -very offset to the upper rhs?
Re: Silme GP seat
Postby pauLI » Fri Mar 18, 2016 11:58 am
Same here, bought a couple and in the end had it cut off, repositioned, welded and the hole drilled out to the correct size
pauLI
Re: Silme GP seat
Postby Kristof Lammy pie » Fri Mar 18, 2016 12:00 pm
Hi, I did know whilst I was trying to find a seat for my gp. But my memory is awful.
I believe the silme seat is a bit different as fitting a replacement cover is a nightmare compared to a giuliari.
I have a spare catch somewhere, if you can take a pic of where your catch is and mine fits your welcome to have it.
Kris
Kristof Lammy pie
Re: Silme GP seat
Postby Storkfoot » Fri Mar 18, 2016 6:22 pm
Thanks for the replies. I shall have a look in the morning and take some measurements.
Mine is a new seat cover and, come to think about it, it did have Silme written on it. It went on quite easily. Maybe they are a bit different :?:
Re: Silme GP seat
Postby ToBoldlyGo » Fri Mar 18, 2016 10:43 pm
I do have both, but they are languising in the darkest recesses of my shed at the moment. I think there is a difference, from what I remember. Not to the overall shape, but to the aperture feeding the air scoop. There is a more pronounced bar on the Giuliari. But that's about it.
Re: Silme GP seat
Postby Storkfoot » Sun Mar 20, 2016 8:35 pm
From taking a few simple measurements with the seat raised, it should all line up. So, I'd say the generic remade seat catch that fits the Giuliari, does fit this too.
Anyway, I'm glad I took this photo as I realised I haven't put any rubber bungs on :roll:
A bit more fettling required then :)
