Upright Stand
Upright Stand
Postby lammydave » Wed Mar 16, 2016 3:01 pm
Hi, The stand on my GP sits almost vertical ... not good as a slight push from behind will knock it over.
This is the 2nd one that does it..
is the only answer to reweld the lugs at a slightly different angle?
lammydave
Re: Upright Stand
Postby hullygully » Wed Mar 16, 2016 6:53 pm
I had to cut both lugs down :shock:
Re: Upright Stand
Postby rossclark » Wed Mar 16, 2016 7:41 pm
Just sit on it a few times on the stand, they'll soon bend.
The stand should be almost vertical, see page 169 Sticky's book.
Re: Upright Stand
Postby lammydave » Thu Mar 17, 2016 6:19 pm
think i'll apply some heat and bend the tabs a bit.....
lammydave
Re: Upright Stand
Postby peejay » Fri Mar 18, 2016 1:13 am
mudwing washers between the u-bracket and outrigger will gain you a few degrees, try 2 each side at first rather than heat treatment.
Re: Upright Stand
Postby lammydave » Fri Mar 18, 2016 7:24 am
peejay wrote:mudwing washers between the u-bracket and outrigger will gain you a few degrees, try 2 each side at first rather than heat treatment.
now there's a thought.... thanks, peejay, i'll give it a shot and report back!
lammydave
Re: Upright Stand
Postby Digger » Fri Mar 18, 2016 8:46 am
I've never heard them called that before (thank you Google) I've always called them Penny Washers..... :)
Digger
Re: Upright Stand
Postby peejay » Fri Mar 18, 2016 9:39 am
Digger wrote:I've never heard them called that before (thank you Google) I've always called them Penny Washers..... :)
i was just being an anorak Digger :)
penny washer is about the size of a penny (no surprise there) but for this job a bigger diameter might be better to spread the load more even if it means cutting a flat on it.
Re: Upright Stand
Postby Warkton Tornado No.1 » Fri Mar 18, 2016 9:42 am
Peejay is what you would call "old" as he used to race horse drawn scooter sidecars @, wait for it, Scooter only racing events!
You get to a certain age & think in Roman numerals so nobody knows how old he is, for sure.
You'd probably have to chop off a limb & count the rings...... ;)
Re: Upright Stand
Postby Digger » Fri Mar 18, 2016 9:51 am
:D
Digger
Re: Upright Stand
Postby lammydave » Fri Mar 18, 2016 10:27 am
same here, john... thought I was gonna go out and buy some!!!
lammydave
Re: Upright Stand
Postby Digger » Fri Mar 18, 2016 11:06 am
No need to smash open the piggy bank then David.... - take care.. ;)
Digger
