Hub Shim
Hub Shim
Postby bendyminge » Mon Mar 07, 2016 1:18 pm
Afternoon gang, I've two rear hub shims of different thicknesses. I'm talking about the wheel side ones btw. Does it matter which one I use there and if so, why?
Ben
bendyminge
Re: Hub Shim
Postby Knowledge » Mon Mar 07, 2016 8:32 pm
This is the shim behind the cone?
I wouldn't have thought it made too much difference. I know some people fit two in order to stop big rear tyres rubbing on the casing, and that doesn't seem to make any difference either.
Let's see if anyone else has an opinion on this.....
Re: Hub Shim
Postby bendyminge » Mon Mar 07, 2016 8:45 pm
That's the puppy, and I was thinking the same, but just wanted to be sure. Thanks Knowledge.
Ben
bendyminge
