Clunky noise
Clunky noise
Postby Alex_amd2001 » Tue Mar 01, 2016 9:39 am
Hi Everybody,
This may be a daft question, but I'm new to Lammys. Just finished my rebuild, registered and on the road. Should there be an audible "clunk" noise as you change gear, or would you expect it to be completely silent? Cheers Alex.
Alex_amd2001
Re: Clunky noise
Postby kennystag » Tue Mar 01, 2016 10:25 am
Is this clunk coming from the gear box, there will be a slight noise when changing gears. Try adjusting your clutch to see if it helps, as I think that's your problem, if it is a problem.
Stag
kennystag
Re: Clunky noise
Postby Scooterlam » Thu Mar 03, 2016 12:18 am
an an uprated selector spring can give an audible clunk when the ball kick out.
Scooterlam
