by eyeguy » Tue Feb 23, 2016 12:47 am
Hi, I am getting ready to send my Li/3 125 to the painter. should the ends of the wheel studs be painted? I was going to mask the whole stud off. Looking at my TV it looks as the tips of the studs are painted. I don't know if this matters or not. Trying to go all original. The pictures shows the wheel primed. I hoping to avoid having to use a die to clean them off after painting.
eyeguy
eyeguy
by dave411 » Tue Feb 23, 2016 9:12 am
I would wrap the studs with masking tape.
dave411
by Wack » Tue Feb 23, 2016 6:56 pm
That's what I do but very often the paint cracks off when fitting the nut. Keep some touch up.
by eyeguy » Tue Feb 23, 2016 7:46 pm
okay, now I'm confused. wrap the studs with tape, but then second post says have some touchup paint.
So are we going to paint the tip of the studs or not? If we are going to keep the tip painted i will leave that part exposed. Sorry to be a pain but the answers contradict.
eyeguy
eyeguy
by Jazzy b » Tue Feb 23, 2016 7:53 pm
I put some old a couple of old nuts on before it goes to painter
Jazzy b
by eyeguy » Tue Feb 23, 2016 8:04 pm
What I did is put shrink tube on the studs. It holds nice and will come off with a small cut of a blade. if i need to leave the tips exposed i can easily do that.
eyeguy
eyeguy
by rossclark » Tue Feb 23, 2016 9:36 pm
I believe the tips of the studs should be painted.
