Rear hub
Rear hub
Postby pauLI » Sun Feb 21, 2016 8:50 pm
advice please
Stripping a bike I recently bought for paint and when I came to take the rear wheel off I noticed that two of the studs had been replaced with flat headed bolts. Should have took a pic! Anyway should I replace the hub for a new one? If so who is making/ selling the best? Or is the hub still serviceable?
pauLI
Re: Rear hub
Postby Knowledge » Sun Feb 21, 2016 11:19 pm
You're right Paul, you should have taken a photo.
If the bolts can be removed and replaced with the correct stud, then it probably can be used safely. I fear that when those bolts are removed, you may find that the thread in the hub lug has been damaged, but you might be surprised. Make sure you buy good studs, because there are some out there which appear to be made of cheese.
If you are looking for a replacement, the Scootopia hub sounds good.
Re: Rear hub
Postby Donnie » Mon Feb 22, 2016 12:00 am
Arent the hub studs left hand thread though? Been ages since I replaced one to be fair so could be wrong.
Donnie
Re: Rear hub
Postby Donnie » Mon Feb 22, 2016 12:02 am
Forgot to say, needed a new hub due to worn splines only 6 months ago myself, couldn't get a scootopia one as out of stock so got the next best thing, sil one from scooter restorations, it's spot on and Ive used indian ones in the past with no issues ( the one it replaced was an fa italia)
Donnie
Re: Rear hub
Postby Jim Rose » Mon Feb 22, 2016 9:03 am
Its worth checking the back of your engine casing because if the bolt heads were proud of the rim they may have worn a groove in the casing.
Jim Rose
Re: Rear hub
Postby pauLI » Mon Feb 22, 2016 10:13 am
Thanks for the replies
the heads were not proud so no worries there
I think I will go new for piece of mind
so who's is the best?
pauLI
Re: Rear hub
Postby Wack » Mon Feb 22, 2016 7:07 pm
Nothing wrong with UNI ones from AF's. The last SIL one's I bought, one was oval and the other cracked the liner after a few months.
Re: Rear hub
Postby burnside » Mon Feb 22, 2016 9:03 pm
burnside
Re: Rear hub
Postby pauLI » Mon Feb 22, 2016 10:02 pm
I assume this type will fit on a GT200 without any issues?
pauLI
Re: Rear hub
Postby Toot » Mon Feb 22, 2016 11:45 pm
Wack wrote:The last SIL one's I bought, one was oval and the other cracked the liner after a few months.
I've heard this a few times now, can I ask was the SIL hub bought from the main UK SIL importer/dealer? (As I stock these on the LCGB Club Shop and not had this issue come back to me with the SIL hubs that I've sold through the Club Shop)?
Toot
Re: Rear hub
Postby Toot » Mon Feb 22, 2016 11:47 pm
Wack wrote:Nothing wrong with UNI ones from AF's.
Can't disagree with this recommendation, sold quite a few through the LCGB Club Shop and carry a spare UNI hub when travelling to rallies on the scoot.
Toot
Re: Rear hub
Postby dave411 » Tue Feb 23, 2016 9:23 am
What other parts are stocked in the Club Shop?
dave411
Re: Rear hub
Postby burnside » Tue Feb 23, 2016 10:53 am
Not tried myself but would assume so
burnside
Re: Rear hub
Postby HxPaul » Tue Feb 23, 2016 11:06 am
Yes,fit straight on no problem.
Re: Rear hub
Postby pauLI » Tue Feb 23, 2016 11:38 am
thanks all
pauLI
Re: Rear hub
Postby Toddy » Tue Feb 23, 2016 1:13 pm
dave411 wrote:What other parts are stocked in the Club Shop?
Simon Carries a large range of Get you home spares oi the club shop which is on sale when attending club events when no dealers are there and some larger events
Re: Rear hub
Postby Wack » Tue Feb 23, 2016 6:54 pm
Yes the SIL hubs were from the big dealer in Nottingham. They replaced the oval one with the one that cracked but after that I bought UNI as certain race teams use them. I was probably just unlucky as I know plenty that use them no probs.
Re: Rear hub
Postby Toot » Tue Feb 23, 2016 10:20 pm
Hi Dave
If you can imagine the types of spares that you might need to buy at a rally to get you home, these are what I keep in stock and carry with me alongside all the usual clothing, badges and stickers, etc. Including:
Rear Hubs, Rims, Inner tubes and Tyres
Plugs, Plug caps and HT Lead
Throttle, Gear and Clutch Cables (inners and complete Nylon Lined cables), Threaded Rear Brake Cables
Clutch Kits - 4 and 5 plate, as well as replacement Clutch Plates, Circlips and Springs
Carb Rubbers, Drain plugs, Exhaust Gaskets, CDI Units and Disc Brake Pads
Electronic Stators, Std and Lightened Flywheels
Levers, Trunnions and Exhaust Springs
Barrels Stud Sets and Bearing Sets
Petrol Tank caps, Straps and Trunnions
Rear Shockers and Reed Valve Petals/Gaskets
Various Oils - Gear and 2 Stroke (Semi and Full Synthetic)
Nuts, Bolts, Woodruff Keys, Stainless and Fibre Washers
Exhaust Nuts and Studs, Rear Hub Stubs and Locking kits
Plus numerous other stuff that I've forgot that I have in the van!!!
All these spares are what the BSM winners & riding companions, my riding partners and myself use on our own Lambretta's. These aren't the top end expensive parts, but neither are they the cheap and cheerful 'use once and replace' parts that are available out there. :shock:
I don't have a massive amount of parts at any one time, (at the AGM I confirmed that stock levels were around £5,000 worth of spares), as I don't consider that it's appropriate that the LCGB becomes a scooter parts dealer in its own right.
The Get You Home Spares service came about as for many of the Affiliated Club Events, and Members Rallies, it hasn't (until recently) been worthwhile for a dealer to be in support of these events all weekend, however with upwards of 400 lambretta riders getting to some of these events now, this situation may be under review..!!! ;)
I also recently seen that the VCB are looking to provide a similar service to their members at events.
Toot
