Wheel rim close to engine casing
Postby Covboy » Sat Feb 20, 2016 4:42 pm
Hi all
Just fitted a wide alloy AF rim to my Italian GP. The rim is very close to the engine casing at one point - maybe 2-3mm.
It spins freely and does not catch the casing. My question is is this normal and is it safe?
Steve
Re: Wheel rim close to engine casing
Postby hullygully » Sat Feb 20, 2016 5:03 pm
if the rim's clear then its clear, I'd be more concerned regarding the tyre, hows the fit with the casing front & sideways?
Postby Covboy » Sat Feb 20, 2016 5:52 pm
Thank you
The tyre has much more clearance. Phew!
