more pulling power
more pulling power
Postby kennystag » Fri Jan 22, 2016 9:45 pm
Hi All,
Staying on the Isle of Skye is very hilly and my GP150 struggles at times, so I am thinking of fitting a bigger barrel,and piston for a bit more pulling power. I have fitted a expansion exhaust and a 22mm jetex carb, an electronic ignition kit, but i need a bit more pulling power. Any recommendations, on what set up would do the job without another mortgage. Any recommendations please on a kit.
Stag
kennystag
Re: more pulling power
Postby Knowledge » Fri Jan 22, 2016 9:52 pm
Hi Kenny,
There is no substitute for cc's. The cheapest tune is a rebore and bigger piston.
150 = 57mm piston
175 = 62mm piston
185 = 64mm piston
A bigger crank, 60mm, will add more torque but not too many cc's.
Plenty of tuners will undertake this work, matching the port to the tune.
I am sure lots of advice will follow. Martin
Postby Dave67 » Fri Jan 22, 2016 10:13 pm
What about a Stage 4 tune? More power and carry on using your existing carb and pipe
Dave67
Postby coaster » Sat Jan 23, 2016 9:40 am
What expansion is it Kenny? some of them push the power up the rev range and won't suit the gearing. If it's power to get up hills you want then a pipe that gives low down torque might be better, JL3 or Franspeed Supertourer or BGM big bore
Postby kennystag » Sun Jan 24, 2016 1:41 pm
Colin thanks, I got the PM.
Stag
kennystag
more pulling power
Postby kennystag » Sun Jan 24, 2016 4:39 pm
Hi All,
I am still looking for recommendations for a bigger barrel, and piston for my GP 150. Can anybody point me to a kit for not a lot of money, as I am looking for a bit more pulling power for hilly Skye
All
Stag
Any comments on this one on ebay
http://www.ebay.co.uk/itm/191326684828? ... EBIDX%3AIT
kennystag
Postby CHRIS in MARGATE » Sun Jan 24, 2016 4:52 pm
Or have your current barrel bored to 62mm and fit a 175 conversion piston and a used 175 head.
Rebore 30
Piston 35
Head 10
Gaskets 5
Oldest proven conversion that will give you some more oomph.
Postby burnside » Sun Jan 24, 2016 4:56 pm
Ask yourself this, do you think it will be quality for that money? These kits are lucky dip you might get an ok one but most of the time they are far from it, but maybe if you bought one and sent it to a tuner then they might be able to sort out the porting, etc. but by the time you have done that you might as well just bought yourself a quality kit in the 1st place.
There are plenty of decent kits out there, the GT and Mugello kits would fit the bill but you are talking around the £500 quid mark plus a decent crank, carb, pipe, etc. Or for a bit less money then the Casa 185 kit would work well
http://www.riminilambrettacentre.com/en/casa-lambretta/kit-185.html
Also you mentioned you have fitted an expansion exhaust, which pipe is it exactly? Expansions don't really with low down torque which you need for tackling hills, etc. I would have thought a clubman would fit the bill better, especially with a 22mm carb. Also what gearing are you running?
burnside
Postby Meds » Sun Jan 24, 2016 5:47 pm
These are my experiences.
I bought second hand Indian barrel like that, rebore it with a reasonable piston etc etc
Then gave up, couldn't get it to run right, just too much bother, waste of £100 in my case, There are others who know much more than me, do well with these kits after a bit of fettling.
I would suggest you speak to a dealer/tuner, tell them what you want and either get yours tuned accordingly with an appropriate exhaust and carb or their recommended kits.
Meds
Postby kennystag » Sun Jan 24, 2016 6:47 pm
Thanks burnside and meds for the answers. The exhaust is a sterling. Quality for the money who know without trying the kit. What I was trying to find out if anybody got a good enough kit at a reasonable price, if not I will go for a 175 rebore.
Stag
kennystag
Postby bazza3004 » Sun Jan 24, 2016 7:47 pm
just bought one of these ally 185 kits from buzzsolomoto. i spoke to them before buying it and was told they 'tidy' them up before selling. the one i got will be going back as the inlet manifold only just covers the port on one side by about 0'5 - 1'0mm and with piston at bdc the transfers are approx 5mm higher then bottom of exhaust port.
Took the kit back to buzz today. Have to say credit were its due. Sorted me out with a decent topend no problem. Nice fella aswell.
bazza3004
Postby Donnie » Sun Jan 24, 2016 11:34 pm
kennystag wrote:Any comments on this one on ebay
I dare not, last time i commented on anything from that particular seller it turned into WW3 online!
Suffice to say" buy that kit, buy a shitload of grief"
Donnie
Postby dickie » Mon Jan 25, 2016 8:09 am
I wouldn't touch it with a barge pole.
The side casing gasket that's included might be ok though
Postby kennystag » Mon Jan 25, 2016 10:04 pm
Hi All,
I got this prices for a rebore and head skim and ect. What do you think of the prices.
Stag
HI KENNY
ARE YOU AFTER AN OVER SIZE REBORE? 50+VAT
ARE YOU AFTER A CONVERSION REBORE? 75+VAT
SKIM HEAD 60+VAT
PISTON VARIOUS PRICES DEPENDS IF THEY ARE FORGED TYPE
185cc 60.00 +VAT
TV175 60.00 +VAT
GP200 60.00 + VAT
225cc 120.00 + VAT
DIFFICULT TO PRICE EXACTLY DUE TO WE DO NOT KNOW WHAT YOU HAVE
DO YOU HAVE ITALIAN OR INDIAN CYLINDER
WHAT SICE DO YOU HAVE AT PRESENT
WHAT SIZE WOULD YOU LIKE TO FINISH WITH
WE CAN REBORE PORT AND TUNE ANY CYLINDER
PORTING WORK IS CHARGED AT 50.00 + VAT PER HOUR
kennystag
Postby CHRIS in MARGATE » Mon Jan 25, 2016 11:08 pm
IMO..Top end prices.
I hate it when it's + vat. Just tell it as it is.
Postby Storkfoot » Mon Jan 25, 2016 11:10 pm
A Sterling is a copy of a PM25, I think. If so, they were made to produce power well up the Rev range. Do you have to slip your clutch to get it moving?
Postby lammydave » Tue Jan 26, 2016 6:47 am
CHRIS in MARGATE wrote:IMO..Top end prices.
agreed on both counts.... one well known seller advertises his stuff on facebook, ex vat ... I told him it was misleading and he said he also sold to the trade, so advertised his prices that way.... I now buy as little as possible from him...
lammydave
Postby kennystag » Tue Jan 26, 2016 10:42 am
Hi ,
Thanks for the answers .
Top end prices ok ,plus VAT, bloody hell I am not a pro football player. There is no way I would pay the prices he is asking, £60 for a head skim, bloody daylight robbery , I could get a 6 cylinder truck head skimmed for £50 not 2 long ago. I will go into my local engineers shop the next time I am in inverness, 200 miles return journey, if I ride my lammy there, the time I get there, it will need a rebore lol. No mate I don’t have to slip the clutch to get her moving.
Stag
kennystag
Postby kennystag » Tue Jan 26, 2016 11:09 am
Hi All,
Someone told me to have a look at this one on ebay, anybody used this kit.
Sta
:) g
http://www.ebay.co.uk/itm/272076885294? ... 21765&cp=1
kennystag
Postby johnnyXS » Tue Jan 26, 2016 1:24 pm
kennystag wrote:Hi All,
Stag
SKIM HEAD 60+VAT
£72.00 for a simple head skim ?? :shock:
You'd want your head looking at to pay that ! :lol: the sad thing is there are presumably plenty of newcomers to classic scootering who are paying those prices
johnnyXS
