Fork springs
Fork springs
Postby stephena » Sun Jan 17, 2016 6:48 pm
Evening all. Just rebuilding the forks on my s3 with new springs they are dual rate with a tighter coil on one end which way round do they go ? Thanks Stephen.
stephena
Re: Fork springs
Postby HxPaul » Sun Jan 17, 2016 7:20 pm
I have progresive springs in both my scooters.I have them built with the tighter coils at the top,but I dont think it matters - I stand to be corrected though.
Re: Fork springs
Postby Nelly » Sun Jan 17, 2016 7:23 pm
From the MB website:-
"Fit them with the tightly wound springs at the top, if not sure balance the spring in the middle of your finger the heavy end will show up.
TOP TIP, there will not be much difference with tight coils at the top or bottom, on the computer they work the same, its all about sprung and unsprung weight, either way always fit the tightly wound springs in the same position."
Nelly
