GP Ignition Switch
GP Ignition Switch
Postby kennystag » Fri Jan 15, 2016 8:27 pm
Hi All,
Is there a difference between AC and DC ignition switches for the GP, as I need a new switch, as the one I have is kind of faulty, the switch that is on is AC I think, as I was running points, I am now have electronic ignition fitted, but I do not to muck it up with the wrong switch. That is why I was wondering if there is a difference between the 2.
Stag
kennystag
Re: GP Ignition Switch
Postby grandpa » Fri Jan 15, 2016 8:57 pm
Hi Kenny
No real difference except the dc switch has a -1 position I.e a position to the left of off to leave parking lights on (if you have battery) and remove key
Grandpa
grandpa
Postby Raveydavey » Sat Jan 16, 2016 8:42 am
I've swapped from 6v ac( points) to 12v dc without changing the ignition, no problem at all.
Raveydavey
Postby kennystag » Sat Jan 16, 2016 11:41 am
Thanks for that info Clive and raveydavey .
Kenny
kennystag
