by 507VBH » Sun Jan 10, 2016 10:28 pm
For some reason my series 2 Li150 has a knackered looking SH1/18 carb rather than the standard MB19 BS7. Does anybody know if these two carbs fit the same inlet manifold?
I put this question in the Carburettors forum so apologies if either of these posts is in the wrong place!
507VBH
by 507VBH » Thu Jan 14, 2016 9:31 pm
The two carbs have a 27.5mm clamping diameter.
507VBH
by Ivor the engine » Tue Jan 19, 2016 1:25 pm
Hi,
As long as you have the longer inlet manifold for the series 2, (a shorter series 3 inlet will have the carb snagging the fuel tap lever).
I'm doing a similar changeover, all seems well with fitment.
Regards,
Ivor.
Ivor the engine
