Mag housing oil seal lip repair
Postby Covboy » Sun Jan 10, 2016 4:11 pm
can this be repaired ? Thinking a dermmel could be used to carefully square up the inside face....
Re: Mag housing oil seal lip repair
Postby Warkton Tornado No.1 » Sun Jan 10, 2016 5:44 pm
That just needs a tidy up to remove the cracked portion.
If you think about what the lip does, it is an abutment for the seal to keep it in place axially.
I have used worse after a clean up, with no issues!
Postby Scooter Paul » Sun Jan 10, 2016 7:02 pm
As above or get really hot and tap it back into shape against a flat, hard surface.
Scooter Paul
Postby dave411 » Sun Jan 10, 2016 8:43 pm
I have a piece missing from mine,not bothered about it.
dave411
Postby monument7 » Mon Jan 11, 2016 1:09 pm
Scooter Paul wrote:As above or get really hot and tap it back into shape against a flat, hard surface.
There's a risk it will break off in use if you do this I would have thought, then it's floating around in the engine. Break it off and tidy it up, just my opinion.
monument7
Postby Scooter Paul » Mon Jan 11, 2016 3:57 pm
It's already apart. If it broke off it could jam against the flywheel and stator coil so I guess it would be safer to break off and file flat.
Scooter Paul
Postby Covboy » Tue Jan 12, 2016 7:41 am
Thanks for the reply fellas .
