GP Clutch thrust bush
PostPosted: Thu Jan 07, 2016 7:04 pm
by jonno
Has anyone machined a bit off the clutch thrust bush to give a bit of clearance,for annoying hard to set up clutches?
Re: GP Clutch thrust bush
PostPosted: Thu Jan 07, 2016 8:50 pm
by Knowledge
No, but it would not be difficult to do.
Could you not get the same effect by fitting one or two extra side-casing gaskets?
PostPosted: Thu Jan 07, 2016 8:53 pm
by DaveTomo
PostPosted: Thu Jan 07, 2016 9:58 pm
by jonno
Wouldnt the thicker gasket affect the kickstart engaging properly?
PostPosted: Thu Jan 07, 2016 11:52 pm
by Warkton Tornado No.1
Yes.
More than once but not for the reason of standard clutches, but the principle applies. I also made up a little bolt in 'cap' so that a non GP cover could use the GP bush. What a tw*t I was! Probably still am, but now I try to use the spigotted clutch centre/bored cluster combination whenever I can. It is by far the best combination to aid clutches clearing fully to avoid broken teeth on first gear.
However, thicker crankcase gaskets work well (CamLam's last forever) & the kickstart engagement is something I've fiddled with as well in the past. Lengthened the slot, fitted a longer, stronger spring. That was to suit an old school six plate clutch with a SII cover & the kickstart shaft moved outboard to suit by cutting back the inner face.
Eventually that cover started to crack but I added steel reinforcement rings shrunk on & all was fine again.
