by Paullr » Tue Dec 29, 2015 2:41 pm
Hi all
Anyone got a dimension for weld on bracket for anti-dive front brake
I know the recommendation is to try clamp on first but i want to weld on and paint
Paul
Paullr
by rossclark » Tue Dec 29, 2015 10:21 pm
Only recommendation would be to dry fit it and see where the anti-dive arm falls more or less parallel to the links. This could vary for different brake and caliper carrier combinations or manufacturers.
by Paullr » Thu Dec 31, 2015 8:22 am
Ta Ross
Yeh was trying to avoid the dry run as the scooter is being done from scratch do i dont want to build up forks etc to try. But it might be the only way
Paul
Paullr
by hullygully » Sun Jan 10, 2016 2:21 pm
50mm long x 22 to 25mm wide x 5mm thk, with a 9mm hole 11mm min from one radiused end
