Gear. Change e clip
Gear. Change e clip
Postby steve t » Wed Dec 23, 2015 8:42 pm
Any one know gear tie bar e clip size I think it's 5 mm but not sure thanks in advance merry xmas
steve t
Re: Gear. Change e clip
Postby Dimitrios_231 » Wed Dec 23, 2015 9:17 pm
5mm ;)
Dimitrios_231
Postby steve t » Wed Dec 23, 2015 9:40 pm
Thanks dimitrios you are a wealth of useful information cheers :D
steve t
Postby coaster » Thu Dec 24, 2015 1:52 am
I bought a box of various sizes from Maplin which includes the size for the gear linkage as well as PHBH needle clips and brake levers...should last me a lifetime 8-)
Postby JETEX » Fri Dec 25, 2015 2:09 am
I got so fed up with that tiny circlip, I took the opportunity when rebuilding my engine to cut the small 'stud' off the arm, drilled and tapped it out, and fitted a 6mm stud. I drilled the tie rod to suit, put the tie rod on, a wavy washer, then a nyloc nut. Tighten the nut until a slight resistance to turn is felt on the tie rod. Job done - no more circlip !. To make it look a bit neater, I put a plastic cap over the nyloc nut.
JETEX
Postby coaster » Fri Dec 25, 2015 11:20 am
That's a mod I keep meaning to do
Postby rossclark » Fri Dec 25, 2015 11:54 pm
Worth it + change to early Li clamp on change lever.
Postby jonw » Sat Dec 26, 2015 10:21 am
MB sell already converted arms which offer the same improvements...
http://www.lambrettaspares.com/spares/g ... 0406k.html
jonw
Postby Adam_Winstone » Sat Dec 26, 2015 1:13 pm
Drill through on the line of the circlip groove and use an 'R' clip.
Postby CHRIS in MARGATE » Sat Dec 26, 2015 1:22 pm
Now that is a great idea !
Postby JETEX » Tue Dec 29, 2015 2:08 am
Adam_Winstone wrote:Drill through on the line of the circlip groove and use an 'R' clip.
Or a split pin ?
JETEX
Postby rossclark » Tue Dec 29, 2015 11:39 am
R clip is reusable, small split pins rarely are.
Postby dave411 » Tue Dec 29, 2015 12:55 pm
Agree,a very good idea.Now,wheres my drill.
dave411
Postby Adam_Winstone » Tue Dec 29, 2015 1:15 pm
I did once post a photo of my assembly, which I'll go and try to find now.
Yep, the benefit of the R clip, over split pin, is that it is reusable.
PS - Found the photo so give me an email address and I'll send it over... as I'm too lazy to upload to a webhost and then post it on here :lol:
PPS - I've done a number of mine on a small pillar drill, simply centre punching it on the circlip groove, then running a small drill through to the other side.
Postby CHRIS in MARGATE » Tue Dec 29, 2015 4:10 pm
You've got to admit that is ridiculously simple yet such an improvement. Next time !
Postby Adam_Winstone » Tue Dec 29, 2015 6:39 pm
Thanks Chris
Postby bike grim » Tue Dec 29, 2015 8:22 pm
Excellent idea. Never seen it before. Nicking it, thanks.
Postby JETEX » Wed Dec 30, 2015 1:26 am
Makes you wonder why Innocenti didn't do this in the first place.
JETEX
Postby davla » Wed Dec 30, 2015 1:46 am
jonw wrote:MB sell already converted arms which offer the same improvements...
Blimey, that's pricy! It's an easy mod to do yourself, even with limited tools. From memory I used a stainless engine casing stud.
davla
Postby rossclark » Wed Dec 30, 2015 11:22 am
JETEX wrote:Makes you wonder why Innocenti didn't do this in the first place.
Cheaper
