lights have a slight flicker
Postby kennystag » Sat Dec 05, 2015 7:46 pm
Hi All,
I have just fitted electronic ignition on my GP, But the lights have a slight flicker front and back lights stop light also, Any ideas what’s going on.
Stag
kennystag
Re: lights have a slight flicker
Postby missing lynx » Sat Dec 05, 2015 10:02 pm
a bad connection some were
Postby Jazzy b » Sun Dec 06, 2015 10:31 am
Faulty cdi ? Sorry ment regulator
Jazzy b
Postby MickYork » Sun Dec 06, 2015 10:39 am
could be the regulator......lots of guess work involved with Lambretta electrics :?
Running AC only you normally get a flicker at low rev's which stabilise as the rev's increase.
Going full DC is the way forward......
Postby grandpa » Sun Dec 06, 2015 10:53 am
Hi Kenny,
Connect a 55watt car headlamp to the stator output it should shine brightly, proving the stator can handle a load.If it is flickering then fault on stator ,possibly earth rivets
loose,otherwise fault on scoot..... bad contacts or bad earth.
Grandpa
grandpa
Postby MK Monty » Sun Dec 06, 2015 8:59 pm
It certainly wont be the CDI
MK Monty
Postby rossclark » Sun Dec 06, 2015 9:25 pm
MK Monty wrote:It certainly wont be the CDI
Agree it won't be the CDI, ignition circuit should be completely separate unless you've got a short or nipped the wires on the stator.
It's normal to have a flicker on AC systems at tickover but it should even out when you rev it up a bit. If it still flickers when you rev it suspect loose connections or bad earths.
Postby kennystag » Mon Dec 07, 2015 2:16 pm
Hi All,
Thanks for all the replies, I have checked it all out, the problems is in the stator, if it is a problem, lose wire bad connection, I will have a look at the stator later and keep all informed.
Stag
kennystag
