Small block kit/standard carb
Postby wibblethorpe » Tue Dec 01, 2015 9:22 pm
Just stripped a Spanish LI motor, wanting to upgrade to modern alloy kit but still retain a 20 or 22 standard carb & the smaller bore exhaust. I thought the V1 mugello years ago could take this set up but I'm not really up to speed with the kits available now.
Any info appreciated - thanks
wibblethorpe
Re: Small block kit/standard carb
Postby Scooterlam » Tue Dec 01, 2015 10:42 pm
Casa 185 gives a bit more than standard and has had some good revues.
Scooterlam
Postby MK Monty » Tue Dec 01, 2015 11:03 pm
+2
Faster kits around but you need to look at cranks gears etc. You can keep what you have with a chain and front sprocket up size and it will pull like a train. Some say you will have problems getting Pistons but mainly coz they don't go wrong. Everyone has pistons and rings for a Muggy
MK Monty
Postby HxPaul » Tue Dec 01, 2015 11:33 pm
MK Monty wrote:+2
Check this out http://www.riminilambrettacentre.com/en ... 185cc.html
Users browsing this forum: Google [Bot] and 144 guests
