Clutch arm shaft?
Clutch arm shaft?
Postby Lammer205 » Mon Jun 23, 2014 10:11 pm
Hi ,
At the bottom of a GP clutch arm below the actuator should there be a washer and an e-clip? Lammer205
Lammer205
Re: Clutch arm shaft?
Postby Digger » Tue Jun 24, 2014 7:54 am
Yes.
Digger
Postby Lammer205 » Tue Jun 24, 2014 9:53 am
Thank you.
Lammer205
Postby a.lo » Tue Jun 24, 2014 8:43 pm
this was something i could not find any info on, i.e the correct sequence of clips, shims, o-rings etc. not covered in sticky,s.
but i fitted a circlip to the bottom as i have only seen them fitted to all engines i owned/dismantled.
a.lo
Postby Digger » Wed Jun 25, 2014 5:29 am
The parts diagrams on SR's website are very handy at times..... :idea:
Digger
Users browsing this forum: Google [Bot] and 73 guests
