by Granty » Thu Nov 26, 2015 5:46 pm
Guys -- as above whats the thoughts on the best spare wheel carrier for sip tubless & would a sip tubless rim fit on a normal legshield spare wheel carries on series 2?
Granty
by Rich Oswald » Fri Nov 27, 2015 2:15 pm
Not sure about the best, it's just personal choice, but on either legshield or rear I think you will need longer studs to fasten the wheel to, I certainly did on my rear one.
by Adam_Winstone » Fri Nov 27, 2015 2:59 pm
I have long cylinder nuts fitted to my carrier studs then a washer, then the spare, then bolts trough from the outside into the long nuts. I've not had the wheel come loose to date.
by Granty » Fri Nov 27, 2015 4:23 pm
Adam_Winstone wrote:I have long cylinder nuts fitted to my carrier studs then a washer, then the spare, then bolts trough from the outside into the long nuts. I've not had the wheel come loose to date.
Thanks Boys -- this looks like the best option for me I think -- thanks for the heads up - G
Granty
by Adam_Winstone » Fri Nov 27, 2015 6:55 pm
Soz, I should have pointed out that I actually use alan key type bolts on the outside, rather than hex head, so that they seat correctly in the SIP rims.
