by Luke » Wed Nov 18, 2015 11:13 pm
I have what I believe to be a S3 LI/SX/TV side casing and a S3 LI/SX/TV kickstart shaft! When I fit the kickstart shaft to the side casing I only have enough of the kickstart shaft sticking out/protruding to fit the circlip only and no room to fit the kickstart shim!
The mating faces of the inside of the side casing and the kickstart shaft where it rotates are fully meeting, so there is no gap there!
I am assuming that if the kickstart shim is left off, I will damage the kickstart seal when starting the scoot??
Any feedback/solution much appreciated!!!!!
Luke
Luke
by rossclark » Thu Nov 19, 2015 12:08 am
There was a modification to remove some from the inside of the casing, could be a post mod shaft and a non modified casing?
by Dimitrios_231 » Thu Nov 19, 2015 12:20 am
GP shaft with earlier S3 side cover,MB has a good skimming tool for this job.
Dimitrios_231
by HxPaul » Thu Nov 19, 2015 11:33 am
Check that the kickstart shaft bush that fits in the casing is flush with the inside of the case,if it sticks out just a bit it can cause the problem that you're describing.
by Luke » Thu Nov 19, 2015 7:18 pm
Kickstart bush in casing is flush so I may have to get casing skimmed!
Thanks for help
Luke
Luke
by MK Monty » Thu Nov 19, 2015 9:07 pm
I did my last one with a router, used a strait cutting bit and trimmed it a bit at a time. The aluminium is quite soft and it was done hand held without a problem. I pushed the inner bush through then trimmed it with a flap disk as is a a bit harder. I have used a flap disk in the angle grinder and thats worked fine as well. Try and borrow a tool if you must but you will not need it again
MK Monty
by Luke » Thu Nov 19, 2015 10:33 pm
Good idea!
Cheers Monty
Luke
Users browsing this forum: Google [Bot] and 54 guests
